Re: Low Oil Pressure
[Re: Stroker Scamp]
#2575349
11/07/18 03:10 PM
11/07/18 03:10 PM
crabman173
crabman173
Kink in oil pressure line? While doing the headers? Copper or nylon easy to damage
[Re: Anonymous]
#2696378
09/11/19 01:13 AM
09/11/19 01:13 AM
Posts: 3,518 pacific northwest
Stroker Scamp
pacific northwest
Part of the problem was a bad battery not spinning the engine as fast, oil pressure is good now with the new filter and new oil I think might have had a stuck bypass? but we are all good now, just need to reset the valves. Hope this helps someone down the road
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
[Re: Stroker Scamp]
#2734249
01/18/20 04:35 PM
01/18/20 04:35 PM
Stroker Scamp
pacific northwest
Want to update on this, still not happy with how long it takes to build pressure. it takes over 30-40 seconds of cranking. It does build up but not like it use to. So pulled the pan and took the pump out, opened the pump and it was clean inside relief valve moves freely I can see oil up on the cam and pistons. So I have pressure but why so long to build after no internal changes? Thoughts and Thanks
[Re: johnzgarage]
#2735390
01/21/20 07:44 PM
01/21/20 07:44 PM
Posts: 43,352 Bend,OR USA
Cab_Burge
Have you split open a oil filter? I have ![puke puke](/ubbthreads/images/graemlins/custom/puke.gif) years ago(1973 or 1974) on the first Hemi stocker we where racing in NHRA stock, 50W Valvoline oil and 20F outside air temp breaking in the cam in the drive way at 2000 RPM, bang it split down the center, what a mess ![down down](/ubbthreads/images/graemlins/custom/down.gif) As far as oil filters and bypassing, I like my motors to get clean oil, not with larger particle in it due to the filter bypassing 40% cold oil ![work work](/ubbthreads/images/graemlins/custom/work.gif)
[Re: Stroker Scamp]
#2735400
01/21/20 08:18 PM
01/21/20 08:18 PM
Stroker Scamp
pacific northwest
Want to update on this, still not happy with how long it takes to build pressure. it takes over 30-40 seconds of cranking. It does build up but not like it use to. So pulled the pan and took the pump out, opened the pump and it was clean inside relief valve moves freely I can see oil up on the cam and pistons. So I have pressure but why so long to build after no internal changes? Thoughts and Thanks When installing the new hedders I had to raise the motor and looks like I dented the pan enough to have the pickup make a witness mark on the bottom of the pan. Also had a thick layer of brown sludge where the pick up sits (oil is Clean). Cleaned the pan and ready to put back together I hop it was just a combo of those 2. No clue what the sludge was, not abrasive and no metal and yes I bent the pan back
[Re: Cab_Burge]
#2735402
01/21/20 08:22 PM
01/21/20 08:22 PM
Posts: 4,324 Prospect, PA
BSB67
Prospect, PA
Have you split open a oil filter? I As far as oil filters and bypassing, I like my motors to get clean oil, not with larger particle in it due to the filter bypassing 40% cold oil How do you measure the bypass quantity?
[Re: BSB67]
#2735484
01/22/20 02:37 AM
01/22/20 02:37 AM
Cab_Burge
Have you split open a oil filter? I As far as oil filters and bypassing, I like my motors to get clean oil, not with larger particle in it due to the filter bypassing 40% cold oil How do you measure the bypass quantity? Wix has stated that their race filters with internal bypass bypass 200 % more(40% vs,20% than the stock filters do, they have also stated that their stock bypass filter can bypass up to 20 % with cold oil at the lower air temps, below 40F. No rumors or I think I heard kind of information from me!
[Re: Cab_Burge]
#2735496
01/22/20 07:52 AM
01/22/20 07:52 AM
BSB67
Prospect, PA
Have you split open a oil filter? I As far as oil filters and bypassing, I like my motors to get clean oil, not with larger particle in it due to the filter bypassing 40% cold oil How do you measure the bypass quantity? Wix has stated that their race filters with internal bypass bypass 200 % more(40% vs,20% than the stock filters do, they have also stated that their stock bypass filter can bypass up to 20 % with cold oil at the lower air temps, below 40F. No rumors or I think I heard kind of information from me! Ok. You're not actually measuring, just using supplier literature. So the literature is saying that the valve is twice as big, so it can theoretically bypass twice as much. But in reality, it will only bypass the amount needed to control/balance the pressure differential dictated by the bypass relief. You will not actually know if, when, or how much oil is bypassed. Arguably, another good reason to not use a high volume oil pump and high viscosity oil.
[Re: Wirenut]
#2735812
01/23/20 12:05 PM
01/23/20 12:05 PM
Posts: 1,715 central il.
second 70
central il.
I had a similar evasive pressure problem. Car would have pressure then lose it. Prime it with a drill and great pressure. Long story short it was a cracked pickup tube that finally broke off at the block (rb motor) Same here except a hemi. Car would prime fine cold with a full pan of oil and be fine for quit awhile and hold 75psi until enough oil stayed in the top of the engine to get level below crack and would lose it's prime when the rpms were reduced.
