Hood pin lanyard lengths - help with definitive list #2509726
06/17/18 08:33 PM
06/17/18 08:33 PM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
There doesn't appear to be any definitive list online.
What I've found so far. And I'm sure this list is basically the cars that actually CAME with hood pins. For example I'm sure the 13" lanyards would fit all Duster and Dart Sports to 76.
6" black rubber coated - For 69-1/2" A12 lift-off hood cars.
Important Notes: The rivets in the hood pin bezels are at 12, 3, 6 and 9 o'clock as you look at any given bezel from the front of the hood. All the lanyards are on the inside rivets.
13" 70-72(76) Duster, 71-72 Scamp
(13" Duster factory lanyard length verified)
18" 70-74 Challenger (assuming TA also), 70-72 (76) Dart, 71-72 Demon? 69 Daytona (per Moparts member Daytona)
3586156 - TA Hood pin kit
23" 70-74 Barracuda (assuming AAR also), 70 B Bodies, 70 Superbird (per Moparts member DAYCLONA)
25" 68-69 & 71-74 B Bodies
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: Hood pin lanyard lengths - help with definitive list [Re: 71TA] #2509729
06/17/18 08:42 PM
06/17/18 08:42 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Originally Posted By 71TA
69 Daytona, 70 Superbird
Superbird - saw some online info where there was some dispute over 23 or 25" lanyards.
23" is the "norm" for the wingcars, 25" is what the aftermarket has assigned to them...
But to add even more pot stirring, here's an early road test photo from back in the day of a 69 Daytona hoodpin lanyard...
Re: Hood pin lanyard lengths - help with definitive list [Re: 71TA] #2509809
06/18/18 12:34 AM
06/18/18 12:34 AM
Banana Republic
FM3AAR Offline
FM3AAR  Offline
Banana Republic
Interesting thread. Being curious, I went out and measured the AAR and I came up with 26" eyelet to eyelet. They look ancient but I guess they got changed at some point in the 70's?
“You’ll own nothing” — And “you’ll be happy about it.”
K. Schwab
Re: Hood pin lanyard lengths - help with definitive list [Re: FM3AAR] #2510268
06/19/18 02:33 AM
06/19/18 02:33 AM
Iowa
Davtona Offline
Davtona  Offline
Iowa
Daytona's were originally 18" long.
Re: Hood pin lanyard lengths - help with definitive list [Re: 71TA] #2510326
06/19/18 11:13 AM
06/19/18 11:13 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
If you want your list to be as accurate as possible...
Hood pins were only available on E-bodies in 70-71. twocents
Re: Hood pin lanyard lengths - help with definitive list [Re: burdar] #2510339
06/19/18 12:02 PM
06/19/18 12:02 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
G-series option report says 795 1971 Plymouth GTX's left the factory with hood pins installed...
Or a little over 29% of production...
Re: Hood pin lanyard lengths - help with definitive list [Re: RSNOMO] #2510390
06/19/18 02:22 PM
06/19/18 02:22 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Burdar was disqualifying 72-4 E bodies from the list... not "other" models
Re: Hood pin lanyard lengths - help with definitive list [Re: 71TA] #2510410
06/19/18 03:17 PM
06/19/18 03:17 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Correct. No hood pins on 72-74 E-bodies.
Re: Hood pin lanyard lengths - help with definitive list [Re: 71TA] #2510437
06/19/18 05:12 PM
06/19/18 05:12 PM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
I do understand that hood pins weren't factory for the later models BUT if they wanted to add them then I'd like the info in the list to be correct. Thanks.
Re: Hood pin lanyard lengths - help with definitive list [Re: RSNOMO] #2510520
06/19/18 09:01 PM
06/19/18 09:01 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
And mine is one of them.
