Low Oil Pressure
#2509783
06/17/18 11:06 PM
06/17/18 11:06 PM
Posts: 3,518 pacific northwest
Stroker Scamp
pacific northwest
Took the Scamp for a drive and the oil pressure was dropping to zero on the gauge at idle, rpms up it increases but still low. Changed to different headers and wondering if the header too close to the oil filter could create such a drastic change. The Hedmans are a bit closer than the TTI's were to the filter, no other changes except different mufflers. Motor was only running for about 10 minutes max, oil level full and about 85* outside Thoughts?
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
Re: Low Oil Pressure
[Re: Stroker Scamp]
#2509789
06/17/18 11:15 PM
06/17/18 11:15 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
First step try a new gage then maybe screw on a new filter so you can cut that one apart and inspect for anything that shouldn’t be there.
[Re: Cab_Burge]
#2511036
06/20/18 08:51 PM
06/20/18 08:51 PM
Stroker Scamp
pacific northwest
Update, tried new gauge no pressure, took filter off and cranked the motor over nothing from the filter as far as pressure What to check next? 1. oil drive shaft stripped? 2, drop the pan and new pump? any way to bench test a pump? Any else you can think of Im all ears Thanks
[Re: Stroker Scamp]
#2511040
06/20/18 09:00 PM
06/20/18 09:00 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Common on chevies but rare on mopars but you may have to drop the pan to check the oil pickup. How did the oil filter look as far as contamination. Good, bad. If bad it has to come apart anyway. If it’s a pump at least they are pretty cheap. If it’s bearings, not so much.
[Re: pittsburghracer]
#2511042
06/20/18 09:01 PM
06/20/18 09:01 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Sounds like you should pull the distributor and try a priming tool and a drill
#2511086
06/20/18 10:33 PM
06/20/18 10:33 PM
Stroker Scamp
pacific northwest
Common on chevies but rare on mopars but you may have to drop the pan to check the oil pickup. How did the oil filter look as far as contamination. Good, bad. If bad it has to come apart anyway. If it’s a pump at least they are pretty cheap. If it’s bearings, not so much. Filter looked good so I put it back on, pulled distr. and primed with a drill, had to rev drill pretty good but have pressure at gauge and to the rockers. If I remember correctly I have a 10-30 weight oil where I usually run the 20-50 Valvoline race oil (they were out) can the change in viscosity make that big of a difference? or possibly oil pump getting weak?
[Re: Stroker Scamp]
#2511103
06/20/18 10:53 PM
06/20/18 10:53 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Just curious but what kind of filter. And yes viscosity can affect it but also remember the drill rpm doesn’t duplicate engine rpm. Years ago I ran 40 weight, then 30, then 10-40, now 10-30. With the RacePak I can closely watch what is going on during a pass and in the pits.
#2511123
06/20/18 11:28 PM
06/20/18 11:28 PM
Stroker Scamp
pacific northwest
Just curious but what kind of filter. And yes viscosity can affect it but also remember the drill rpm doesn’t duplicate engine rpm. Years ago I ran 40 weight, then 30, then 10-40, now 10-30. With the RacePak I can closely watch what is going on during a pass and in the pits. I run a Napa Gold and always have, going to put the Valvoline back in and change filter one at a time to see whats up. Thanks for the tips
[Re: Stroker Scamp]
#2511125
06/20/18 11:33 PM
06/20/18 11:33 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
He already took the filter off the block and cranked it to find no oil coming out of block. What does the filter have to do with anything? Waste of time and money to try a different filter at this point.
[image][/image]
[Re: sgcuda]
#2511127
06/20/18 11:36 PM
06/20/18 11:36 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
He already took the filter off the block and cranked it to find no oil coming out of block. What does the filter have to do with anything? Waste of time and money to try a different filter at this point. Read his post above. He has oil pressure now but it’s not as high
[Re: Stroker Scamp]
#2511128
06/20/18 11:38 PM
06/20/18 11:38 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Just curious but what kind of filter. And yes viscosity can affect it but also remember the drill rpm doesn’t duplicate engine rpm. Years ago I ran 40 weight, then 30, then 10-40, now 10-30. With the RacePak I can closely watch what is going on during a pass and in the pits. I run a Napa Gold and always have, going to put the Valvoline back in and change filter one at a time to see whats up. Thanks for the tips No problem I hope all turns out well for you
[Re: Stroker Scamp]
#2511140
06/21/18 12:04 AM
06/21/18 12:04 AM
Posts: 11,739 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Going from 20-50 to 10-30 will make a difference. But not a 30-40 PSI difference. I use a 1/2 drill and 2 hands to spin the pump with authority while priming. If you're spinning the pump easily with a 3/8, something's fishy. Wide open with an 800 RPM 1/2 drill should get 60-70 PSI and running the drill slow maybe 30. If not, I would try another filter for the heck of it before looking deeper.
[Re: Stroker Scamp]
#2511147
06/21/18 12:23 AM
06/21/18 12:23 AM
RapidRobert
Filter looked good so I put it back on, pulled distr. and primed with a drill, had to rev drill pretty good but have pressure at gauge and to the rockers. how much pressure?
[Re: RapidRobert]
#2511172
06/21/18 01:53 AM
06/21/18 01:53 AM
Stroker Scamp
pacific northwest
went back to original gauge and primed with a 3/8 drill 68 psi, so something made the gauge drop to zero, the hunt is on. will let you know what I find
[Re: Stroker Scamp]
#2511175
06/21/18 01:59 AM
06/21/18 01:59 AM
Posts: 43,315 Bend,OR USA
Cab_Burge
went back to original gauge and primed with a 3/8 drill 68 psi, so something made the gauge drop to zero, the hunt is on. will let you know what I find Maybe some tiny bit of debris in the bypass valve in the pump making it stick open when it acted up hot? ![work work](/ubbthreads/images/graemlins/custom/work.gif) I've seen that more than once in BB, they are a lot easier to check also ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) Good luck, you will find it ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: Cab_Burge]
#2511188
06/21/18 02:11 AM
06/21/18 02:11 AM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
If you tried this the first time right after changing the oil sometimes it takes a little longer to pick up pressure
#2575180
11/07/18 03:10 AM
11/07/18 03:10 AM
Stroker Scamp
pacific northwest
Finally had a chance to get out to the shop (house remodel) pulled the filter and cut it open, no metal Drained the oil and going to let it set overnight covered so I can inspect tomorrow, looked pretty good so far think I will try another filter and the 20-50 Valvoline oil I normally run and see what happens. I will update my findings and thanks for the advice
[Re: Stroker Scamp]
#2575347
11/07/18 03:09 PM
11/07/18 03:09 PM
crabman173
crabman173
Kink in oil pressure line? While doing the headers? Copper or nylon easy to damage
