Re: High performance engines and pcv systems
[Re: mopar dave]
#2508490
06/14/18 05:39 PM
06/14/18 05:39 PM
Posts: 8,031 Mt Morris Michigan
mopar dave
Mt Morris Michigan
Heres something from speedway motors for $20. If i want black i just paint them. Cheap fix. Just bore another hole next to the current one and mount side by side. Function and fashion. Use pcv on other cover. Should get plenty of air flow and raised up keep oil where its suppose to be.
[Re: mopar dave]
#2508513
06/14/18 06:41 PM
06/14/18 06:41 PM
Posts: 4,206 New York
polyspheric
New York
A little crude looking but cheap and effective: 1. big (at least 3/4") fitting in each valve cover, with a baffle inside to mask splash 2. big hose goes away from the engine sideways 3. to a big horizontal cylinder on top of the inner fender (largest diameter that allows the hood to close) 4. if possible, cylinders should drain back to the covers when stopped, otherwise a drain and hose to empty it 5. huge volume is possible: 3" OD × .060" wall cylinder 24" long is over 300" for both 6. a backfire will blow the connecting hose off, so strength is useless in the cylinder itself - no moly, no carbon fiber, just mild exhaust tubing 7. not as effective as an extension to the pan because a. limited by hose size b. air blowing up from the pan fights oil drain from the heads
Boffin Emeritus
[Re: mopar dave]
#2508532
06/14/18 07:34 PM
06/14/18 07:34 PM
Posts: 4,457 Washington
madscientist
Washington
I'd be inclined to deal with the blow by before trying to crutch ring seal with a PCV system. That's not what they are for.
That said, I'd seal the engine and run your PCV system closed and run pan evacs with it. You can get a negative pan pressure doing it that way.
Not as much as with a vacuum pump but more than what you have now.
[Re: mopar dave]
#2508552
06/14/18 08:39 PM
06/14/18 08:39 PM
madscientist
Washington
Then I'd consider a vacuum pump.
[Re: mopar dave]
#2508574
06/14/18 10:04 PM
06/14/18 10:04 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
I remember. Im also looking at running pvc on one side and double elevated breathers side by side on the other cover. Plenty of flow thru with that too. See if i can post a pic later. 2 is a waste of time and $$$ really...........I run a K&N open breather with a home made wrap around piece of tin to limit excess oil spray...........
[Re: mopar dave]
#2508613
06/14/18 11:18 PM
06/14/18 11:18 PM
Posts: 20,755 A collage of whims
topside
A collage of whims
GM and others have been using electric vacuum pumps on street cars for a long time. On a sound 500HP engine with normal ring tension, the factory setup has worked for me. On my Duster drag car, when it wasin the 11s & no mufflers, a pan evac worked. When I got greedy, with low-tension rings as part of the revised combo, put it in the low 10s, and added a bit of 3.5" exhaust & Bullets to meet a Db rule, the pan evac wasn't as effective, some smoke from the pipes. Changed to a regular GM electric vac pump & vented puke tank. Fixed. Sucks out of one valve cover, pulls 5" of vacuum measured at fitting on opposite valve cover.
[Re: mopar dave]
#2508616
06/14/18 11:24 PM
06/14/18 11:24 PM
Posts: 43,129 Bend,OR USA
Cab_Burge
I ended up running two PCV and two screw in breather caps, one of each on each side on my old 518 pump gas street 400 stroker motor I had a old set of Cal Custom cast aluminum valve covers on it with a single PVC and breather cap on the other side, it would push oil out of the breather cap when racing it on the weekends shifting at or above 7000 RPM I added three more breathers caps which helped but did not cure the oil pushing out the caps, adding two PVC with two caps did end up curing it I do make and use a crankshaft scrapers also, they help I run six quarts in a stock 1970/1971 Mopar Street Hemi, 440 six pack oil pan also, I do not overfill it
[Re: topside]
#2508716
06/15/18 03:26 AM
06/15/18 03:26 AM
Thumperdart
State of confusion
GM and others have been using electric vacuum pumps on street cars for a long time. On a sound 500HP engine with normal ring tension, the factory setup has worked for me. On my Duster drag car, when it wasin the 11s & no mufflers, a pan evac worked. When I got greedy, with low-tension rings as part of the revised combo, put it in the low 10s, and added a bit of 3.5" exhaust & Bullets to meet a Db rule, the pan evac wasn't as effective, some smoke from the pipes. Changed to a regular GM electric vac pump & vented puke tank. Fixed. Sucks out of one valve cover, pulls 5" of vacuum measured at fitting on opposite valve cover. I know of a few people running those and some like em some don't but I pull 12+ in. of vacuum cruising and around 7 idling so I'll stick to this BUT, at wot the 5" is better then the 0-2 in. of vacuum a lot probably see there...........
[Re: mopar dave]
#2508721
06/15/18 04:24 AM
06/15/18 04:24 AM
madscientist
Washington
Ok Cab. This is the pan i bought from you. Thought you said to use 1/2 qt over pan capacity to avoid sucking pan dry thru 1/4? Thought it was a 8qt, nope its a 7qt. So you say to use 6qts? May be main problem with oil pushing out with high rpm. If you are sucking the pan dry on a 1/4 mile pass you have issues. There is no POSSIBLE way to suck a pan dry like that. If the pick up is .250 from the floor of the pan (depending on the pick up) like it should be you can't suck a 5 quart pan dry in one pass. I guess you could have some issue with oil return and the heads are holding oil it's POSSIBLE. If that's the case, the fix isn't more oil in the pan. It's to figure out how to get the oil out of the heads. I thought the old wives tale of sucking pans dry was gone. Evidently not.
