Re: How much does rear gear ratio effect HWY gas mileage?
[Re: 360view]
#2509694
06/17/18 06:57 PM
06/17/18 06:57 PM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
... Notice that in nearly all BSFC graphs the best spot is at low vacuum but at an engine speed where the pistons are moving less than 1500 feet per minute. ... Thinking EFI on an earlier built car, which ofcourse is lacking EGR; What would one think of, instead of normally optimizing ignition timing at cruise rpm, now retarding ignition timing instead. Letting the engine get a bit less eficient so more throttle is needed to maintain speed. More throttle, less vacuum (with same speed). Would this have a similar effect as an EGR?
[Re: ragtop]
#2509849
06/18/18 07:19 AM
06/18/18 07:19 AM
Posts: 2,468 Answering the call of the wild
ThermoQuad
That's a lot of turd polishing there....no that's a lack of knowledge on your part...and showing it on the internet
The fsm is a poor substitute for proper bearing preload. Trying to figure out how to make a 1970 automobile go 140 mph without vibration and stopping issues will lead one to figure out how to set up front bearing preload with the proper tool. It does indeed effect gas mileage and proper braking.
Rolling resistance and engine efficiency is the issue here and it does not matter what kind of car it is.
[Re: ragtop]
#2509940
06/18/18 12:32 PM
06/18/18 12:32 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Most authors of articles in the media have a degree in "useless studies" and know virtually nothing about what they write about. What qualifies them as "knowledgeable" is that they know slightly more than the other "journalists" they consort with.
[Re: 360view]
#2510068
06/18/18 05:36 PM
06/18/18 05:36 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
Monday Wall Street Journal has a front page article on getting better MPG from pickup trucks. Author of article seems to believe that simply putting a very small cubic inch engine in a pickup is the majority of the effort. Almost no discussion of gearing and transmissions. I’d bet a 440 would get better mileage in a fully loaded c-body, than a slant 6 would, all other options being the same.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: ragtop]
#2510176
06/18/18 10:02 PM
06/18/18 10:02 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Axle efficiencies come into play. The internals of the transmission [working through a fluid] driveshaft and axle gears [working through a fluid] have to spin at higher rates, consuming more energy.
Lower [numerically] gear sets offer increased efficiencies, this can be seen in the trucking industry by just researching "downspeeding". If you have the torque on-tap, slowing everything down offers a benefit in fuel economy.
By improvement, I am referring to single digit percentages, which may or may not be significant to you. In trucking, it's a big deal. If I turn a 13 or 15 liter engine 200 times less per minute while producing adequate torque, it doesn't take long to realize there is some energy conservation taking place.
For what it's worth, I do work for a Class 8 truck OEM and have spent some time on the subject.
[Re: cudaman1969]
#2510200
06/18/18 10:59 PM
06/18/18 10:59 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
Big engine or little engine, still takes the same hp to go a certain mph, all things equal on the vehicle. but when the smaller engine makes 1/2 the power the larger engine does, it's going to be working harder at that same hp level.
[Re: Spaceman Spiff]
#2510227
06/18/18 11:52 PM
06/18/18 11:52 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Big engine or little engine, still takes the same hp to go a certain mph, all things equal on the vehicle. but when the smaller engine makes 1/2 the power the larger engine does, it's going to be working harder at that same hp level. No, they will be doing the same work, actually the bigger one would as it has to overcome friction from bigger parts or longer strokes or both.
[Re: ragtop]
#2510228
06/18/18 11:56 PM
06/18/18 11:56 PM
HotRodDave
Kalispell Mt.
Also the smaller engine has less distance within the chamber for the flame front to travel across. And since the smaller engine will be operating at a lower vacuume leval the air and fuel molecules will be closer together upon ignition and therefore will burn more completly. Goody could probably back this one up as that is the reason why they run engines with just barely enough power to pull the maximum load the maximum desired speed and then gear it to get the load moving.
[Re: ragtop]
#2510291
06/19/18 08:23 AM
06/19/18 08:23 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
I learned a lot about engine performance under different pavement, grade, wind and speeds using this relatively inexpensive add-on trip computer: http://www.autospeed.com/cms/article.html?&title=The-OzTrip-Car-Computer&A=0639At the time I bought mine 62 USA pennies equalled a Austrailan Dollar. After having the Oztrip for awhile I realized I could go beyond the instant MPG and use the trick of first reseting one of the three mileage memory counters, then watching the Gallons digital readout until it changed by exactly 1.00 gallons, or 2.00 gallons, etc As AndyF says above, seeing how fuel consumption changes as you drive is very educational. Climbing 4% grade hills at the same MPH in different transmission gears is eye opening.
[Re: HotRodDave]
#2510386
06/19/18 02:13 PM
06/19/18 02:13 PM
Posts: 2,255 IL
furious70
IL
Big engine or little engine, still takes the same hp to go a certain mph, all things equal on the vehicle. but when the smaller engine makes 1/2 the power the larger engine does, it's going to be working harder at that same hp level. No, they will be doing the same work, actually the bigger one would as it has to overcome friction from bigger parts or longer strokes or both. +1 If a bigger engine got better or the same mpg tooling around we'd all have bigger engines in our late model cars... Throttle open more = better air and less work to overcome pulling air through the tiny straw of cracked throttle blades.
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: ragtop]
#2510692
06/20/18 09:32 AM
06/20/18 09:32 AM
Posts: 8,162 USA
360view
USA
Anyone here on Moparts presently driving a Ford F150 with the 2.7 L twin turbo V6 ? Does the Ford trip computer allow you to view the MPG at a steady level highway speed? How many psi of boost is needed to drive in the 60 to 75 mph range on a level highway? http://www.wardsauto.com/engines/2018-winner-ford-f-150-27l-ecoboost-twin-turbo-v-6
