Re: 440/512 detonation, run-on and oil consumption
[Re: General 68]
#2516552
07/02/18 07:55 PM
07/02/18 07:55 PM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I’d try running no pcv valve(two breathers)for a while and see what affect that had on the run-on and oil consumption.
[Re: General 68]
#2532282
08/06/18 02:10 PM
08/06/18 02:10 PM
fast68plymouth
So. Burlington, Vt.
The very first thing I would have done is ditch the pcv valve to rule that out as the source of the oil.
That being said, 2.5qts in 240 miles seems like a lot to come from there..... but I would still want to rule that out.
[Re: General 68]
#2532286
08/06/18 02:26 PM
08/06/18 02:26 PM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
Is you pvc baffled under the cover?
Have a great day Iowan
"obsolete is neat"
[Re: Iowan]
#2532341
08/06/18 04:33 PM
08/06/18 04:33 PM
Posts: 401 Norway
General 68
Norway
Pcv has a baffle but it might be ineffisient. Quite small compaired to those in the stamped covers. I'll rig up a catch can to monitor the oil from the pcv valve. I happen to know the guy who had this actual engine in his car before he sold it to the person we got the car from. He says the engine had no problems when he had it and sent some photos that shows stamped valve covers in opposite to the current M/T covers. The owner between him and us didn't drive the car much due to the oil consumption problem he said had always been there. Might be a combo of different things an a quite interesting case😃 We'll find out. Just need to dig a little deeper😀
