How to strip rust from large items like drums/rotors - DIY #2504505
06/04/18 08:35 PM
06/04/18 08:35 PM
Ball Ground, Georgia
Dixie Offline OP
Dixie  Offline OP
Guys,
I cleaned out a parts barn I had and found some '69 rotors and drums. They have some rust on them. Is there a way to chemically strip them?
I'm thinking of a do it yourself solution I can mix up and put these parts in drum and let soak. Any suggestions on that?
Afterwards, how should I keep them from flash rusting until used? Spray with oil?
Thanks!
Randy
Dixie Restoration Parts
Phone -(770) 975-9898
Phone Hours: M-F 10am-5pm EST
website: www.dixierestorationparts.com
email: mail@dixierestorationparts.com
Veteran owned small business
The Best Parts at a Fair Price.
Re: How to strip rust from large items like drums/rotors - DIY [Re: Dixie] #2504508
06/04/18 08:52 PM
06/04/18 08:52 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
Buy yourself a 5 gallon pail of Evaporust.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: How to strip rust from large items like drums/rotors - DIY [Re: Dixie] #2504523
06/04/18 09:34 PM
06/04/18 09:34 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I use Evaporust, rinse off with hot water (I installed an outside hot water hose bib) & then I spray them down with WD-40 so they do not start to rust.
Re: How to strip rust from large items like drums/rotors - DIY [Re: Dixie] #2504633
06/05/18 01:31 AM
06/05/18 01:31 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Order a 5 gal pail of Evapo-Rust from Northern Tool online, and pick up at the store for no added shipping cost.
Inspect after 30 minute to see progress. Wash off Evapo-Rust before it dries with a 2" paint brush and mineral spirits and wipe with shop rag. Buff with an 8" wire wheel in a drill motor. I can't prove it, but I believe wire brushing slows or prevents rusting.
If all rust down to the bottoms of all rust pits isn't gone, re-immerse and repeat.
If all rust down to the bottoms of all rust pits is gone, wash and wipe with mineral spirits, wire wheel, followed by brushing on phosphoric acid with a 1" nylon paint brush. Wash off acid with mineral spirits before the acid dries. This leaves a very thin and almost invisible coat of acid that almost always prevents re-rusting. If minor re-rusting does occur later, it is easily and quickly removed by re-wetting with phosphoric acid and scrubbing with a Scotch-Brite pad. This works very well on steel body panels waiting for paint that should not be oiled. Wash the Scotch-brite pad immediately with water or it will turn to powder.
I've also used just vinegar and both Evapo-Rust and vinegar on cast iron brake drums with good results. A short dip in Evapo-Rust followed by a vinegar soak seemed to make the rust scale pop off and finish up de-rusting quicker. Use the same methods as above to prevent rust without oil, or you can add oil too if you want.
Re: How to strip rust from large items like drums/rotors - DIY [Re: Dixie] #2504639
06/05/18 01:51 AM
06/05/18 01:51 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes, Evaporust. These drums were soaked overnight, left is before, right is after. The paint is the factory red paint & raw cast iron, no paint.
Re: How to strip rust from large items like drums/rotors - DIY [Re: Dixie] #2505142
06/06/18 11:22 AM
06/06/18 11:22 AM
Dixie Offline OP
Dixie  Offline OP
So, vinegar or evaporust, huh? Ok, I'll give it a shot!
kentj340, that's quite the process, thanks!
Re: How to strip rust from large items like drums/rotors - DIY [Re: Dixie] #2505271
06/06/18 03:42 PM
06/06/18 03:42 PM
Oakville, Ontario, Canada
CDN72SE Online content
CDN72SE  Online Content
Sometimes I do the vinegar and lemon first and then finish it off with the Evaporust. Makes my evaporust last longer.
Re: How to strip rust from large items like drums/rotors - DIY [Re: Dixie] #2505360
06/06/18 08:08 PM
06/06/18 08:08 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
Take them to the machine shop and have them shot blasted
Re: How to strip rust from large items like drums/rotors - DIY [Re: Dixie] #2505434
06/07/18 12:10 AM
06/07/18 12:10 AM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Re: How to strip rust from large items like drums/rotors - DIY [Re: ScottSmith_Harms] #2505567
06/07/18 12:58 PM
06/07/18 12:58 PM
New State
kidmopar Offline
kidmopar  Offline
New State
Scott , That's really great to remove Rust ..... however ...... Won't that like
instantly Re-Rust ? ? ? Do you do anything to prevent that ? shruggy
Use "RPM" ? ? ? on Drums ? ? ? work
Re: How to strip rust from large items like drums/rotors - DIY [Re: kidmopar] #2505609
06/07/18 02:55 PM
06/07/18 02:55 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
On these drums I didnt use RPM (but could have). I seasoned them in my oven like a frying pan. I washed the Evaporust off with Acetone (NOT WATER!) and a 0000 steel wool pad then coated them in heavy bacon grease and popped them in the oven at 250 for 3 hours cooling them slowly for 3 more hours. After I cleaned the pad contact areas with brake cleaner and installed. A month or so of daily driving in mixed weather, zero rust so far smile
Re: How to strip rust from large items like drums/rotors - DIY [Re: Dixie] #2505611
06/07/18 03:06 PM
06/07/18 03:06 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
('Painted' my drums with black POR 15...
Been over 20 years...
They still look like the day the POR went on...
They're behind some Rallyes...
Worked well for longevity, OEM, not so much...
Re: How to strip rust from large items like drums/rotors - DIY [Re: ScottSmith_Harms] #2505699
06/07/18 07:26 PM
06/07/18 07:26 PM
Columbus, GA
Michael Ecks Offline
Columbus, GA
You coated your brake parts with.... bacon grease?
THIS IS THE MOST AWESOME POST EVAR! up
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
Re: How to strip rust from large items like drums/rotors - DIY [Re: Michael Ecks] #2505723
06/07/18 08:24 PM
06/07/18 08:24 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Sure did! ....and now after some hard breaking I get to smell bacon....WINNING! smile
Re: How to strip rust from large items like drums/rotors - DIY [Re: ScottSmith_Harms] #2505739
06/07/18 09:34 PM
06/07/18 09:34 PM
Dixie Offline OP
Dixie  Offline OP
Yummm....B..A..C..O..N...…….
Re: How to strip rust from large items like drums/rotors - DIY [Re: Dixie] #2505751
06/07/18 10:40 PM
06/07/18 10:40 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Sure would be a good reason to eat a big slab of applewood smoked bacon !! up
Re: How to strip rust from large items like drums/rotors - DIY [Re: Dixie] #2505754
06/07/18 10:48 PM
06/07/18 10:48 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I had an opposite thought the day I did it. I had just cooked up a big batch of custom smoked bacon and thought "Wow that sure smells good, wonder what I should do with this all of this awesome grease?" LOL!
*Hey, its a different approach, if you don't experiment you never learn new things smile
Re: How to strip rust from large items like drums/rotors - DIY [Re: Dixie] #2506747
06/10/18 07:30 PM
06/10/18 07:30 PM
MAIne
MoparABE Offline
MoparABE  Offline
MAIne
Maybe you could bottle up the bacon grease and compete with the RPM product? What could you call it?
Re: How to strip rust from large items like drums/rotors - DIY [Re: Dixie] #2506871
06/11/18 12:52 AM
06/11/18 12:52 AM
VA
dragon slayer Offline
VA
If you are allergic to bacon, vegetable oil works and won't hurt any rubber brake parts.
Re: How to strip rust from large items like drums/rotors - DIY [Re: Dixie] #2506905
06/11/18 02:12 AM
06/11/18 02:12 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Can you imagine a life without bacon? eek whiney
*But yes, you can season cast iron with pretty much any kind of oil.
