Re: How to strip rust from large items like drums/rotors - DIY
[Re: Dixie]
#2504633
06/05/18 01:31 AM
06/05/18 01:31 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
Order a 5 gal pail of Evapo-Rust from Northern Tool online, and pick up at the store for no added shipping cost.
Inspect after 30 minute to see progress. Wash off Evapo-Rust before it dries with a 2" paint brush and mineral spirits and wipe with shop rag. Buff with an 8" wire wheel in a drill motor. I can't prove it, but I believe wire brushing slows or prevents rusting.
If all rust down to the bottoms of all rust pits isn't gone, re-immerse and repeat.
If all rust down to the bottoms of all rust pits is gone, wash and wipe with mineral spirits, wire wheel, followed by brushing on phosphoric acid with a 1" nylon paint brush. Wash off acid with mineral spirits before the acid dries. This leaves a very thin and almost invisible coat of acid that almost always prevents re-rusting. If minor re-rusting does occur later, it is easily and quickly removed by re-wetting with phosphoric acid and scrubbing with a Scotch-Brite pad. This works very well on steel body panels waiting for paint that should not be oiled. Wash the Scotch-brite pad immediately with water or it will turn to powder.
I've also used just vinegar and both Evapo-Rust and vinegar on cast iron brake drums with good results. A short dip in Evapo-Rust followed by a vinegar soak seemed to make the rust scale pop off and finish up de-rusting quicker. Use the same methods as above to prevent rust without oil, or you can add oil too if you want.
[Re: ScottSmith_Harms]
#2505567
06/07/18 12:58 PM
06/07/18 12:58 PM
Posts: 3,821 New State
kidmopar
New State
Yes, Evaporust. These drums were soaked overnight, left is before, right is after. The paint is the factory red paint & raw cast iron, no paint. Scott , That's really great to remove Rust ..... however ...... Won't that like instantly Re-Rust ? ? ? Do you do anything to prevent that ? Use "RPM" ? ? ? on Drums ? ? ? ![work work](/ubbthreads/images/graemlins/custom/work.gif)
#2505699
06/07/18 07:26 PM
06/07/18 07:26 PM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
On these drums I didnt use RPM (but could have). I seasoned them in my oven like a frying pan. I washed the Evaporust off with Acetone (NOT WATER!) and a 0000 steel wool pad then coated them in heavy bacon grease and popped them in the oven at 250 for 3 hours cooling them slowly for 3 more hours. After I cleaned the pad contact areas with brake cleaner and installed. A month or so of daily driving in mixed weather, zero rust so far You coated your brake parts with.... bacon grease? ... THIS IS THE MOST AWESOME POST EVAR! ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
#2505739
06/07/18 09:34 PM
06/07/18 09:34 PM
Posts: 2,336 Ball Ground, Georgia
Dixie
Sure did! ....and now after some hard breaking I get to smell bacon....WINNING! Yummm....B..A..C..O..N...…….
[Re: Dixie]
#2505754
06/07/18 10:48 PM
06/07/18 10:48 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Sure would be a good reason to eat a big slab of applewood smoked bacon !! up I had an opposite thought the day I did it. I had just cooked up a big batch of custom smoked bacon and thought "Wow that sure smells good, wonder what I should do with this all of this awesome grease?" LOL! *Hey, its a different approach, if you don't experiment you never learn new things ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif)
