Re: Where to get street hemi orange engine paint
[Re: rickseeman]
#2507174
06/11/18 05:37 PM
06/11/18 05:37 PM
Posts: 43,609 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
I use Bill Hirsch paints... www.hirschauto.com
JB Rhinehart, Realist
A-Body's RULE!
[Re: ScottSmith_Harms]
#2507331
06/11/18 11:53 PM
06/11/18 11:53 PM
Posts: 5,345 Planet Earth
RoadRunnerLuva
Planet Earth
How I prepped it was simple, SUPER clean metal using acetone and phosphoric acid wash to clean the iron. No primer, painted with a gun following Frank's instructions. Laid down nice and hasn't chipped or peeled in the least in 3 years. Nice job on your 340 Scott
Plymouth Makes It!
[Re: PAULS_340]
#2507515
06/12/18 01:51 PM
06/12/18 01:51 PM
Posts: 17,907 S.E. Michigan
ZIPPY
S.E. Michigan
PPG 3116 (Chrysler Mandarin Orange) At your local PPG dealer.
Rich H.
Esse Quam Videri
[Re: John_Kunkel]
#2507547
06/12/18 03:41 PM
06/12/18 03:41 PM
Posts: 2,368 Wheatfield, NY
Cuda340
Wheatfield, NY
PPG doesn't have that color, so who might mix a pint of the correct color? Body color EV2 without the metallic. Unless you have an original parked next to it, nobody will be able to tell the difference. This!
[Re: Cuda340]
#2507559
06/12/18 04:00 PM
06/12/18 04:00 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
PPG doesn't have that color, so who might mix a pint of the correct color? Body color EV2 without the metallic. Unless you have an original parked next to it, nobody will be able to tell the difference. This! That is what I do. Nason Ful-Thane single stage
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: moparmarks]
#2508148
06/13/18 10:12 PM
06/13/18 10:12 PM
Posts: 1,336 Oregon
earlymopar
Just beautiful MOPARMARKS. How is this for a someone to apply who is not experienced with a real spray gun? Do you need high quality regulator / filter / etc.?
- EM
[Re: 65pacecar]
#2509326
06/16/18 01:36 PM
06/16/18 01:36 PM
Posts: 1,043 Motown, Mi
PAULS_340
Motown, Mi
Mostly good info in your responses, NOW, should I prime the assembled engine, or just spray directly to cleaned metal?
Still looking for LM29H1B415501, '71 Demon 340
[Re: PAULS_340]
#2509335
06/16/18 02:15 PM
06/16/18 02:15 PM
Posts: 4,580 Motor City
6PKRTSE
Motor City
Duplicolor engine enamels have always worked great for me. Even used their black wrinkle finish paint on my rocker covers. Came out awesome, perfect amount of wrinkle with heat lamps and heat gun. These were polished alum covers originally.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#2509336
06/16/18 02:22 PM
06/16/18 02:22 PM
Posts: 2,533 God's Country Maryland
GODSCOUNTRY340
Don't prime unless you have a high heat primer. You don't want the primer to lift cause it will take the orange off with it. Clean the metal with Simoniz brake cleaner and spray the top coat.
