Lowered d100 shocks? #2506219
06/09/18 12:16 PM
06/09/18 12:16 PM
mopargilley Offline OP
What shocks are you guys and gals using on lowered 73-up D-100 trucks? Rears seem too long?
Re: Lowered d100 shocks? [Re: mopargilley] #2506266
06/09/18 02:39 PM
06/09/18 02:39 PM
,Pa.
68dodge Offline
68dodge  Offline
,Pa.
only thing you can do is measure the distance you need when you raise the truck off the ground and make sure they are short enough for movement on the ground. This way you can pick which shock to use
Re: Lowered d100 shocks? [Re: mopargilley] #2506298
06/09/18 04:33 PM
06/09/18 04:33 PM
ohio
bbtrux Offline
bbtrux  Offline
ohio
B body shock may work on the rear?
Re: Lowered d100 shocks? [Re: mopargilley] #2506313
06/09/18 05:16 PM
06/09/18 05:16 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
F body are shorter than B body.
Have a great day
Iowan
"obsolete is neat"
Re: Lowered d100 shocks? [Re: mopargilley] #2506331
06/09/18 06:37 PM
06/09/18 06:37 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
too short is as bad as too long.
Re: Lowered d100 shocks? [Re: mopargilley] #2506509
06/10/18 10:18 AM
06/10/18 10:18 AM
E
earlymopar Offline
earlymopar  Offline
E
The other issue is that when you lower your truck, the rear shock mounting angle increases to a point where it can render the shock useless (depending how much you lower the truck). The top or bottom shock mount (or both) should be loved to reduce the shock angle. Anything beyond 30 degrees from vertical is too much.
- EM
