Re: Mopar Race at 42 update
[Re: dvw]
#2507304
06/11/18 10:58 PM
06/11/18 10:58 PM
Posts: 1,444 central ohio
nss guy
central ohio
I am loaded and ready to rock. Doug You going to give us a chance???
[Re: nss guy]
#2507338
06/11/18 11:58 PM
06/11/18 11:58 PM
Posts: 9,897 MI, usa
dvw
MI, usa
I am loaded and ready to rock. Doug You going to give us a chance??? Sooner or latter this is going to end. If someone told me I would have won 30 of my last 31 rds I would have told them they were nuts. Just trying not to beat myself and let the chips fall where they fall. Doug
[Re: max_maniac]
#2507521
06/12/18 02:16 PM
06/12/18 02:16 PM
Posts: 20,204 PA.
pittsburghracer
"Little"John
"Little"John
PA.
If you go and if you are towing with a truck, and have access to a couple of bales of hay you may want to take it along. Especially if it rains anymore this week. There isn’t a bad pit spot at the track but when you pull off the asphalt to park there is about 2-3 feet of mud along the road that you will be driving your race car thru to pit. A vendor or someone was selling hay bales for 6.00 a piece two weekends ago while I was there.
[Re: Clanton]
#2507530
06/12/18 02:42 PM
06/12/18 02:42 PM
Posts: 20,204 PA.
pittsburghracer
"Little"John
"Little"John
PA.
The track has no power outlets so I predict lots of generators running all night. I parked out past the ET shack by Larry smith and yes we used generators. I run my 2000 watt Honda inverter generator all night on low as I use a cpap to sleep. You can’t hear it from 20 feet away. Luckily there weren’t any cheapo brigs n crapin generators nearby.
[Re: Whompin_Wedge]
#2507738
06/12/18 11:38 PM
06/12/18 11:38 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
Are we able to bring vehicles in on the pit side if we aren't racing? Is it extra?
Also, I will bring some corn hole boards. Maybe we can get a little tourney going after the races!
Thanks, Casey FJ I have seen other cars pass in front of the tower at other races but not many.Good question.
[Re: Whompin_Wedge]
#2507758
06/13/18 12:42 AM
06/13/18 12:42 AM
Posts: 6,354 Aurora, Oh.
max_maniac
Aurora, Oh.
Thanks, Casey FJ Yes come in on the pit side and no extra charge!!!
[Re: max_maniac]
#2508142
06/13/18 09:59 PM
06/13/18 09:59 PM
dartman366
Mt. Vernon, Ohio
hope to be rollin in around noon Friday.
[Re: dartman366]
#2508450
06/14/18 03:47 PM
06/14/18 03:47 PM
Posts: 10,563 Rittman Ohio
fourgearsavoy
Rittman Ohio
Well my oil change and lash check showed me why the engine has been ticking a little louder than usual I pulled the drain plug and there was a large wad of sticky gray matter attached to the magnet. Lash was wider than normal on 4 of the valves all the rest were on the money. I actually had to remove some of that crap from the drain plug hole so the oil would come out. I think it's time to step up to a roller so this doesn't happen again, that flat cam has been in there for about 6 years with zero issues. Don't think I will be racing with you guys this weekend Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: max_maniac]
#2509183
06/16/18 12:20 AM
06/16/18 12:20 AM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
Thanks for the pics Mike!
[Re: dvw]
#2509195
06/16/18 01:02 AM
06/16/18 01:02 AM
fourgearsavoy
Rittman Ohio
I am loaded and ready to rock. Doug You going to give us a chance??? Sooner or latter this is going to end. If someone told me I would have won 30 of my last 31 rds I would have told them they were nuts. Just trying not to beat myself and let the chips fall where they fall. Doug Well it didn't end today That awesome Plymouth was in the finals again today and I'm pretty sure he won. Gus
