Re: Mopar Race at 42 update
[Re: dvw]
#2507304
06/11/18 10:58 PM
06/11/18 10:58 PM
Posts: 1,443 central ohio
nss guy
central ohio
I am loaded and ready to rock. Doug You going to give us a chance???
[Re: nss guy]
#2507338
06/11/18 11:58 PM
06/11/18 11:58 PM
Posts: 9,883 MI, usa
dvw
MI, usa
I am loaded and ready to rock. Doug You going to give us a chance??? Sooner or latter this is going to end. If someone told me I would have won 30 of my last 31 rds I would have told them they were nuts. Just trying not to beat myself and let the chips fall where they fall. Doug
[Re: max_maniac]
#2507521
06/12/18 02:16 PM
06/12/18 02:16 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
If you go and if you are towing with a truck, and have access to a couple of bales of hay you may want to take it along. Especially if it rains anymore this week. There isn’t a bad pit spot at the track but when you pull off the asphalt to park there is about 2-3 feet of mud along the road that you will be driving your race car thru to pit. A vendor or someone was selling hay bales for 6.00 a piece two weekends ago while I was there.
[Re: Clanton]
#2507530
06/12/18 02:42 PM
06/12/18 02:42 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
The track has no power outlets so I predict lots of generators running all night. I parked out past the ET shack by Larry smith and yes we used generators. I run my 2000 watt Honda inverter generator all night on low as I use a cpap to sleep. You can’t hear it from 20 feet away. Luckily there weren’t any cheapo brigs n crapin generators nearby.
[Re: Whompin_Wedge]
#2507738
06/12/18 11:38 PM
06/12/18 11:38 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
Are we able to bring vehicles in on the pit side if we aren't racing? Is it extra?
Also, I will bring some corn hole boards. Maybe we can get a little tourney going after the races!
Thanks, Casey FJ I have seen other cars pass in front of the tower at other races but not many.Good question.
[Re: Whompin_Wedge]
#2507758
06/13/18 12:42 AM
06/13/18 12:42 AM
Posts: 6,354 Aurora, Oh.
max_maniac
Aurora, Oh.
Thanks, Casey FJ Yes come in on the pit side and no extra charge!!!
[Re: max_maniac]
#2508142
06/13/18 09:59 PM
06/13/18 09:59 PM
dartman366
Mt. Vernon, Ohio
hope to be rollin in around noon Friday.
[Re: dartman366]
#2508450
06/14/18 03:47 PM
06/14/18 03:47 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
Well my oil change and lash check showed me why the engine has been ticking a little louder than usual ![down down](/ubbthreads/images/graemlins/custom/down.gif) I pulled the drain plug and there was a large wad of sticky gray matter attached to the magnet. Lash was wider than normal on 4 of the valves all the rest were on the money. I actually had to remove some of that crap from the drain plug hole so the oil would come out. I think it's time to step up to a roller so this doesn't happen again, that flat cam has been in there for about 6 years with zero issues. Don't think I will be racing with you guys this weekend ![frowwn frowwn](/ubbthreads/images/graemlins/custom/frowwn.gif) Gus ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: max_maniac]
#2509183
06/16/18 12:20 AM
06/16/18 12:20 AM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
Thanks for the pics Mike!
[Re: dvw]
#2509195
06/16/18 01:02 AM
06/16/18 01:02 AM
fourgearsavoy
Rittman Ohio
I am loaded and ready to rock. Doug You going to give us a chance??? Sooner or latter this is going to end. If someone told me I would have won 30 of my last 31 rds I would have told them they were nuts. Just trying not to beat myself and let the chips fall where they fall. Doug Well it didn't end today ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) That awesome Plymouth was in the finals again today and I'm pretty sure he won. Gus ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
