Page 3 of 3 1 2 3
Re: Anyone with a Cope VB have a 3rd gear flare up [Re: mopar dave] #2506557
06/10/18 12:45 PM
06/10/18 12:45 PM
Cedar Lake IN
CRT Offline
CRT  Offline
Cedar Lake IN
I did have a valve body issue with 1 out of 10 with a flair up. 10 years ago dave did have a issue. I took his valve body and installed it in my race car and it did have a flair up in 3rd. I grab a vb off the shelf and install it in my car. No flair up. Same vb. Same cnc program. So the issue was not in all the vbs but still there.
I did update the vb ( 10 years ago ) and if any one with my vb that bought the vb from me. I will up date the vb for free. If you bought the vb second hand or used from some one, the update is 30 bucks. This update is for a slight flair up into 3rd. And that's it.
A100 is my internet stalker.
Re: Anyone with a Cope VB have a 3rd gear flare up [Re: CRT] #2506670
06/10/18 04:45 PM
06/10/18 04:45 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Ok, I readjusted the front band which did seem like it was way out(alot of turns). Readjusted the the shift cable which was out of adjustment a bit(may not of been pushing lever enough for for 3rd). Went for a ride today. Run it up to 7000 wot and shifted into 3rd and NO FLARE UP. Did this 2 times and no flare ups. So i will leave this Cope vb in for now and see how it goes. No flare up into 3rd but it does seem soft going it.
Re: Anyone with a Cope VB have a 3rd gear flare up [Re: mopar dave] #2506672
06/10/18 04:48 PM
06/10/18 04:48 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
That was a fun ride I bet.
Re: Anyone with a Cope VB have a 3rd gear flare up [Re: Clanton] #2506689
06/10/18 05:19 PM
06/10/18 05:19 PM
Mt Morris Michigan
Mt Morris Michigan
Fun for sure but little crazy around here. not too far out of the city and wot into 3rd is around 80 or 90mph. A bit over the limit anyway.
Re: Anyone with a Cope VB have a 3rd gear flare up [Re: mopar dave] #2506691
06/10/18 05:20 PM
06/10/18 05:20 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
If it's soft now it my have hurt itself from being misadjusted.
Re: Anyone with a Cope VB have a 3rd gear flare up [Re: dizuster] #2506732
06/10/18 06:38 PM
06/10/18 06:38 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I think this is where a trans temp gauge will help slippage is heat
Re: Anyone with a Cope VB have a 3rd gear flare up [Re: Clanton] #2506757
06/10/18 07:48 PM
06/10/18 07:48 PM
Mt Morris Michigan
Mt Morris Michigan
I use a trans temp gauge. its never been over 185* with this trans.
Page 3 of 3 1 2 3
