Page 2 of 3 1 2 3
Re: Anyone with a Cope VB have a 3rd gear flare up [Re: 340Cuda] #2505625
06/07/18 03:48 PM
06/07/18 03:48 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Have you ever talked to John Cope? You better hope you catch him on a good day.
Re: Anyone with a Cope VB have a 3rd gear flare up [Re: mopar dave] #2505637
06/07/18 04:25 PM
06/07/18 04:25 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
Many times. Must be I have never caught him on a "Bad" day. He always answers the phone and answers my questions. Never had a negative conversation with the man personally.
I am running his VB and it is one of the best purchases I have made for my car.
Hope you get your issue figured out. Make sure you post and let us know what the problem was.
Re: Anyone with a Cope VB have a 3rd gear flare up [Re: cl440] #2505640
06/07/18 04:45 PM
06/07/18 04:45 PM
Georgia
66coronet Offline
66coronet  Offline
Georgia
Same for me. We run his parts in both our cars. Never had an issue speaking to him.
Re: Anyone with a Cope VB have a 3rd gear flare up [Re: cl440] #2505649
06/07/18 05:12 PM
06/07/18 05:12 PM
Mt Morris Michigan
Mt Morris Michigan
I think first thing i will do is double check my shift cable adjustment. Readjust bands just so i know where there set. Next step will be getting a new vb to eliminate this one as the issue. Let you know how it goes.
Re: Anyone with a Cope VB have a 3rd gear flare up [Re: mopar dave] #2505651
06/07/18 05:18 PM
06/07/18 05:18 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
I've bought three transmissions from John, he is short and to the point but always helps me with my questions and everything always works as it should for the most part too
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Anyone with a Cope VB have a 3rd gear flare up [Re: bigdad] #2505656
06/07/18 05:26 PM
06/07/18 05:26 PM
East Brunswick New Jersey
N
NoFrills Offline
NoFrills  Offline
N
I have one of his valvebodys in my dart no issues. I would say if it slipped more then once going into high gear it needs to come out and come apart.
Re: Anyone with a Cope VB have a 3rd gear flare up [Re: mopar dave] #2505660
06/07/18 05:37 PM
06/07/18 05:37 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
I've heard Hemi Super Stock cars with just a touch of flare on the gear change. I would expect they are wanting to stay away from overlap which can slow the car down. Flare and slip are not the same thing although flare is hard on the high gear clutch pack. Flare can also be tuned out.
Re: Anyone with a Cope VB have a 3rd gear flare up [Re: mopar dave] #2505683
06/07/18 06:54 PM
06/07/18 06:54 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Put the trans in neutral and the shifter in neutral. Adjust cable until it drops into the shift lever. I know it sounds elementary, but a couple of friends have struggled with this... wrench realcrazy
'63 Dodge 330
11.19 @ 121 mph
Re: Anyone with a Cope VB have a 3rd gear flare up [Re: 66coronet] #2505758
06/07/18 11:06 PM
06/07/18 11:06 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Ditto , the tranny in my car has all of his parts and his transbrake VB and it works flawless and has from day 1, altho John did not do the assembly ( I did ) I set it up to his spec's,, I suspect it is in the adjustment's as the second gear release and the high gear apply happens in milliseconds and is not usually the VB that causes that but a mis adjusted shifter,intermediate band or clutch clearance,, now as far as mechanical then the item list is a lot greater and I could go on and on.
Re: Anyone with a Cope VB have a 3rd gear flare up [Re: GomangoCuda] #2505767
06/07/18 11:31 PM
06/07/18 11:31 PM
Mt Morris Michigan
Mt Morris Michigan
Actually he wants 12 springs with 1 spring in the servo. Just what i have.
Re: Anyone with a Cope VB have a 3rd gear flare up [Re: dartman366] #2505770
06/07/18 11:39 PM
06/07/18 11:39 PM
Mt Morris Michigan
Mt Morris Michigan
Well my trans builder has put together a couple trannys for me using turbo action, A&A and Cope valve bodies. Only time i had any issues was when they had a Cope vb. The first time i had this issue i removed the Cope vb and installed an A&A vb. Problem solved just by switching out vb's. Now i have another of Copes vb's and i have that same issue again.
Re: Anyone with a Cope VB have a 3rd gear flare up [Re: mopar dave] #2505773
06/07/18 11:49 PM
06/07/18 11:49 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
My next trans brake will be A&A.
Re: Anyone with a Cope VB have a 3rd gear flare up [Re: mopar dave] #2506020
06/08/18 07:57 PM
06/08/18 07:57 PM
Mt Morris Michigan
Mt Morris Michigan
Trying to find a griner. Anyone out there have a clean one for sale? An A&A is my second choice. 727 rmvb.
Re: Anyone with a Cope VB have a 3rd gear flare up [Re: mopar dave] #2506045
06/08/18 09:09 PM
06/08/18 09:09 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I have a Cope Manual Reverse Valve Body (MRVB), no trans brake version in my 727. Bought it around 2010, so however they were built back then?
Haven't had any problems with it. Running 4.2:1 band lever, and the billet oversized front servo with the extra seals. No restrictor in the case. Modified front support max lug pump, and billet steel drum. Alto red clutches and Kolene steels. I think the bands are the Mopar Performance kevler, they are not the red lined ones many prefer.
Re: Anyone with a Cope VB have a 3rd gear flare up [Re: mopar dave] #2506108
06/08/18 11:34 PM
06/08/18 11:34 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Few years back Cope used A&A vakve bodies on his transmissions
My 904 is a Cope super pro unit, among other tbings it has an A&A brake valve body in it.
Was built in late 2014.
Just installed the tranny, shifts ultra nicely. Dont intend to use it other than footbraking.
I have a 727 i just took out that has a rvmb in it i havent taken pan off of to see what it was. In the car when i bought it
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Anyone with a Cope VB have a 3rd gear flare up [Re: B3422W5] #2506187
06/09/18 10:44 AM
06/09/18 10:44 AM
Mt Morris Michigan
Mt Morris Michigan
Still looking for a Griner. Looks like i will most likely end up with an A&A since they seem to be the best thing going next to the Griner vb. Will be adjusting front band and checking shift cable today. Will be ordering something monday.
Re: Anyone with a Cope VB have a 3rd gear flare up [Re: mopar dave] #2506395
06/09/18 10:30 PM
06/09/18 10:30 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
Call joe at transzact in Indy build a nice bullit brake heard he used to work for grinner
Re: Anyone with a Cope VB have a 3rd gear flare up [Re: mopar dave] #2506478
06/10/18 03:52 AM
06/10/18 03:52 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Pro Trans also builds brakes in house. I’m currently running one of there clean N trans brakes.
Re: Anyone with a Cope VB have a 3rd gear flare up [Re: J_BODY] #2506511
06/10/18 10:25 AM
06/10/18 10:25 AM
BigFish69 Offline
BigFish69  Offline
Keep looking for a good used Griner much quicker off the brake than the A&A
Re: Anyone with a Cope VB have a 3rd gear flare up [Re: BigFish69] #2506540
06/10/18 12:01 PM
06/10/18 12:01 PM
Mt Morris Michigan
Mt Morris Michigan
Not looking for a brake, just a good Griner RMVB.
Page 2 of 3 1 2 3
