Re: Speedometer gear? [Re: Cab_Burge] #2672071
06/30/19 07:41 PM
06/30/19 07:41 PM
#1 confirm the actual error with a GPS or interstate mile markers (go 5 miles/5 markers) for the odo & should go (1) mile in 1 minute with the speedo dead on 60 MPH for the speedo & usually when the speedo reads correct the odo will also but if not the speedo head would need to be sent to a speedometer specialty shop tho some people have successfully tweaked em at home. get the right speedo gear in there to correct the odo then see if the speedometer reads MPH correct. there's a bunch for sale on eBay & FABO, not cheap tho but it is important to get it dead on. EDIT meant to say that usually when the odo reads correct the speedo does also
Re: Speedometer gear? [Re: TJP] #2672087
06/30/19 08:20 PM
06/30/19 08:20 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Pretty much guarantee that adapter won't fit the early TF setup.
Notice that in the early setup the adaoter is part of the speedometer cable itself.
A 1964-65 B-BODY, 1963-65 CHRYSLER/IMPERIAL cable pictured, A body similar
Re: Speedometer gear? [Re: Cab_Burge] #2672222
07/01/19 05:48 AM
07/01/19 05:48 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Originally Posted by Cab_Burge
The early 727 push button speedometer gears are not interchangeable with the 1966 and later 727 whiney Way different in size shruggy
Also a totally different design.
Re: Speedometer gear? [Re: Morty426] #2672243
07/01/19 07:20 AM
07/01/19 07:20 AM
RWG75
RWG75
Interstate highway mile markers are a pretty reliable way to judge the offset. Sometimes state routes (2 lane black top) will also have them. The thing I did many moons ago: grab a car I knew read correctly, drive it about 10 miles, turn around. Note what it read out / back / combined. Take the exact same run in the one I knew didn't (tire, axle change) then calculate the offset. Put the tail on ramps to keep the fluid in the trans and swap gears then re-run the loop. As a final sanity check, I go looking for one of those road side construction zone things that flash your speed at you.
Re: Speedometer gear? [Re: ] #2672277
07/01/19 08:24 AM
07/01/19 08:24 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
You can put an app on your phone that will tell you you speed continuously, they are pretty accurate and easier than any other method I seen listed.
Re: Speedometer gear? [Re: Sniper] #2672403
07/01/19 10:19 AM
07/01/19 10:19 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
They can split the cable and install the necessary fittings to place it anywhere between the cable ends wink beer
Re: Speedometer gear? [Re: TJP] #2672475
07/01/19 11:32 AM
07/01/19 11:32 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
That gets beyond just buying a ratio adapter, particularly when it would be substantially cheaper and easier to just get the right pinion.
Re: Speedometer gear? [Re: Sniper] #2672490
07/01/19 12:01 PM
07/01/19 12:01 PM
On a side note on the odo & speedo, if one of em is inaccurate I'd rather have the speedo correct. tickets ain't cheap!
Re: Speedometer gear? [Re: Sniper] #2672691
07/01/19 07:03 PM
07/01/19 07:03 PM
RWG75
RWG75
Here's the thing with that: some of us were swapping gears before smart phones existed and old habits die hard.
Re: Speedometer gear? [Re: ] #2672701
07/01/19 07:26 PM
07/01/19 07:26 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
True, but around here finding a mile marker is harder than finding gold at the end of a rainbow.
Re: Speedometer gear? [Re: TJP] #2673062
07/02/19 02:24 PM
07/02/19 02:24 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Here's what the early reduction gear looks like.
Re: Speedometer gear? [Re: Sniper] #2674200
07/04/19 07:15 PM
07/04/19 07:15 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
GEEZ!!! just offering the guy an option, it's his decision, not either one of ours rolleyes
Re: Speedometer gear? [Re: John_Kunkel] #2674201
07/04/19 07:17 PM
07/04/19 07:17 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
beer
