Re: Anyone with a Cope VB have a 3rd gear flare up
[Re: mopar dave]
#2505637
06/07/18 04:25 PM
06/07/18 04:25 PM
Posts: 2,560 S.E. Michigan
cl440
S.E. Michigan
Have you ever talked to John Cope? You better hope you catch him on a good day. Many times. Must be I have never caught him on a "Bad" day. He always answers the phone and answers my questions. Never had a negative conversation with the man personally. I am running his VB and it is one of the best purchases I have made for my car. Hope you get your issue figured out. Make sure you post and let us know what the problem was.
[Re: cl440]
#2505640
06/07/18 04:45 PM
06/07/18 04:45 PM
Posts: 826 Georgia
66coronet
Georgia
Have you ever talked to John Cope? You better hope you catch him on a good day. Many times. Must be I have never caught him on a "Bad" day. He always answers the phone and answers my questions. Never had a negative conversation with the man personally. I am running his VB and it is one of the best purchases I have made for my car. Hope you get your issue figured out. Make sure you post and let us know what the problem was. Same for me. We run his parts in both our cars. Never had an issue speaking to him.
[Re: mopar dave]
#2505651
06/07/18 05:18 PM
06/07/18 05:18 PM
Posts: 34,884 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
I've bought three transmissions from John, he is short and to the point but always helps me with my questions and everything always works as it should for the most part too
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: mopar dave]
#2505660
06/07/18 05:37 PM
06/07/18 05:37 PM
Posts: 11,552 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I've heard Hemi Super Stock cars with just a touch of flare on the gear change. I would expect they are wanting to stay away from overlap which can slow the car down. Flare and slip are not the same thing although flare is hard on the high gear clutch pack. Flare can also be tuned out.
[Re: 66coronet]
#2505758
06/07/18 11:06 PM
06/07/18 11:06 PM
dartman366
Mt. Vernon, Ohio
Have you ever talked to John Cope? You better hope you catch him on a good day. Many times. Must be I have never caught him on a "Bad" day. He always answers the phone and answers my questions. Never had a negative conversation with the man personally. I am running his VB and it is one of the best purchases I have made for my car. Hope you get your issue figured out. Make sure you post and let us know what the problem was. Same for me. We run his parts in both our cars. Never had an issue speaking to him. Ditto , the tranny in my car has all of his parts and his transbrake VB and it works flawless and has from day 1, altho John did not do the assembly ( I did ) I set it up to his spec's,, I suspect it is in the adjustment's as the second gear release and the high gear apply happens in milliseconds and is not usually the VB that causes that but a mis adjusted shifter,intermediate band or clutch clearance,, now as far as mechanical then the item list is a lot greater and I could go on and on.
[Re: mopar dave]
#2506108
06/08/18 11:34 PM
06/08/18 11:34 PM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
Few years back Cope used A&A vakve bodies on his transmissions My 904 is a Cope super pro unit, among other tbings it has an A&A brake valve body in it. Was built in late 2014. Just installed the tranny, shifts ultra nicely. Dont intend to use it other than footbraking. I have a 727 i just took out that has a rvmb in it i havent taken pan off of to see what it was. In the car when i bought it
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
