Re: Speedometer gear?
[Re: Cab_Burge]
#2672071
06/30/19 07:41 PM
06/30/19 07:41 PM
RapidRobert
#1 confirm the actual error with a GPS or interstate mile markers (go 5 miles/5 markers) for the odo & should go (1) mile in 1 minute with the speedo dead on 60 MPH for the speedo & usually when the speedo reads correct the odo will also but if not the speedo head would need to be sent to a speedometer specialty shop tho some people have successfully tweaked em at home. get the right speedo gear in there to correct the odo then see if the speedometer reads MPH correct. there's a bunch for sale on eBay & FABO, not cheap tho but it is important to get it dead on. EDIT meant to say that usually when the odo reads correct the speedo does also
[Re: TJP]
#2672087
06/30/19 08:20 PM
06/30/19 08:20 PM
Posts: 6,356 nowhere
Sniper
nowhere
Pretty much guarantee that adapter won't fit the early TF setup. Notice that in the early setup the adaoter is part of the speedometer cable itself. A 1964-65 B-BODY, 1963-65 CHRYSLER/IMPERIAL cable pictured, A body similar ![[Linked Image]](http://www.brewersperformance.com/prodimages/large/SC52CC-1.jpg)
[Re: Morty426]
#2672243
07/01/19 07:20 AM
07/01/19 07:20 AM
RWG75
RWG75
Interstate highway mile markers are a pretty reliable way to judge the offset. Sometimes state routes (2 lane black top) will also have them. The thing I did many moons ago: grab a car I knew read correctly, drive it about 10 miles, turn around. Note what it read out / back / combined. Take the exact same run in the one I knew didn't (tire, axle change) then calculate the offset. Put the tail on ramps to keep the fluid in the trans and swap gears then re-run the loop. As a final sanity check, I go looking for one of those road side construction zone things that flash your speed at you.
[Re: Sniper]
#2672403
07/01/19 10:19 AM
07/01/19 10:19 AM
Posts: 15,565 Omaha Ne
TJP
Omaha Ne
Pretty much guarantee that adapter won't fit the early TF setup. Notice that in the early setup the adaoter is part of the speedometer cable itself. A 1964-65 B-BODY, 1963-65 CHRYSLER/IMPERIAL cable pictured, A body similar They can split the cable and install the necessary fittings to place it anywhere between the cable ends ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
[Re: Sniper]
#2672490
07/01/19 12:01 PM
07/01/19 12:01 PM
RapidRobert
On a side note on the odo & speedo, if one of em is inaccurate I'd rather have the speedo correct. tickets ain't cheap!
[Re: Sniper]
#2672691
07/01/19 07:03 PM
07/01/19 07:03 PM
RWG75
RWG75
You can put an app on your phone that will tell you you speed continuously, they are pretty accurate and easier than any other method I seen listed. Here's the thing with that: some of us were swapping gears before smart phones existed and old habits die hard.
[Re: TJP]
#2673062
07/02/19 02:24 PM
07/02/19 02:24 PM
Posts: 26,036 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Here's what the early reduction gear looks like.
