Re: How much does rear gear ratio effect HWY gas mileage?
[Re: ragtop]
#2507843
06/13/18 11:00 AM
06/13/18 11:00 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
They invented a neat way to calculate that a long time ago, F=ma.
[Re: ragtop]
#2508157
06/13/18 10:30 PM
06/13/18 10:30 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
long story here... my first car was a '79 Grand LeMans when i was 14 in 1991. Nice enough car, factory buckets, and console. 350 chevy from a '73 monte carlo( according to the numbers) being i had a few years before i could drive it, and being young and dumb, not fully understanding drivetrain " combinations' , i decided to start modifying. i did a comp cams " 268 high energy" cam, dual plane intake/650 holley, and cheap headers, and a custom dual exhaust that my dad paid for as a gift. ( the car was flatbeded to the muffler shop for this, as i still has a few months before i got my license.) now comes the first drive... should move pretty good with the things i did right? NO. the thing was a stone. i remember getting passed by a full size dodge conversion van, who looking back now, probably didn't even know i was floored... and it got horrible mileage. BUT it did loaf along at something like 2,000 rpm at 70... after 1 to many 1 wheel burnouts, the rear exploded. THAT'S when i started to understand it's not just about the engine.... pulling the cover and counting ( what was left) of the teeth, i had to count multiple times to believe what i was seeing.. a 2.29 final drive ratio. being a broke kid going to high school working something like 20 hours a week, for minimum wage, i borrowed money from my father to buy a complete rear from a monte carlo SS. that had 3.73's. Holy Moly! did it wake that car up! it would burn the tires going into 2nd gear. not only did the performance improve, so did the mileage! i could not go almost 2 weeks before fill up, where as before, it was at least once a week! but hey, premium was only about $1 then!
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: ragtop]
#2508878
06/15/18 01:25 PM
06/15/18 01:25 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
my 2000 dodge van with a 5.9 and 3.92s is close to that fluctuation and it definately locks solid in lock up. It will not hold the speed as precise as my 2011 1500 ram did on the data stream on my scanner or in real life on the freeway running side by side.
I have a set of 3.21s to install, I am positive they will give me better highway MPG.
[Re: cudaman1969]
#2508883
06/15/18 01:31 PM
06/15/18 01:31 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
Just checked my van rpm to speed, 4.10 2930-50 @ 60 mph for 15 miles on a hand held diagnostic. 5.9 Magnum 2001. Couple of questions, is this a good rpm for that engines "sweet" spot? Also It's got a lock up converter but the rpm, set at 60 mph on cruise, fluctuates from 1888 to 1955 up and down slight grades but the hand held never goes off 60, is this normal for a new lockup? Take out of overdrive it goes to 2770 rpm @ 60 Thanks It has more rpm in overdrive?
[Re: Spaceman Spiff]
#2508911
06/15/18 02:24 PM
06/15/18 02:24 PM
Posts: 8,249 fredericksburg,va
cudaman1969
fredericksburg,va
Just checked my van rpm to speed, 4.10 2930-50 @ 60 mph for 15 miles on a hand held diagnostic. 5.9 Magnum 2001. Couple of questions, is this a good rpm for that engines "sweet" spot? Also It's got a lock up converter but the rpm, set at 60 mph on cruise, fluctuates from 1888 to 1955 up and down slight grades but the hand held never goes off 60, is this normal for a new lockup? Take out of overdrive it goes to 2770 rpm @ 60 Thanks It has more rpm in overdrive? "Take out of overdrive"
[Re: HotRodDave]
#2508920
06/15/18 02:36 PM
06/15/18 02:36 PM
cudaman1969
fredericksburg,va
Interesting, my scanner would stay at 60 then going down a hill would creep to 61 but rpm would go down to 1888. All over the place. I'm thinking the converter is not locking up to well (all new parts, electrical and trans). Will the lockup fluctuate 100 rpm? I have a set of 3.54 for the Dana that I would like to try. Talked to the Dodge service man, he said no problem reflashing pcm for the ratio change.
[Re: cudaman1969]
#2509041
06/15/18 06:25 PM
06/15/18 06:25 PM
HotRodDave
Kalispell Mt.
Interesting, my scanner would stay at 60 then going down a hill would creep to 61 but rpm would go down to 1888. All over the place. I'm thinking the converter is not locking up to well (all new parts, electrical and trans). Will the lockup fluctuate 100 rpm? I have a set of 3.54 for the Dana that I would like to try. Talked to the Dodge service man, he said no problem reflashing pcm for the ratio change. Dont waste money taking it to the dodge dealer for a "flash" after a ratio change, the vehicle speed is measured after the gears and will not affect anything computer related changing gears.
[Re: mgoblue9798]
#2509045
06/15/18 06:26 PM
06/15/18 06:26 PM
HotRodDave
Kalispell Mt.
I don't know what your combo is, but I have a 2002 Ram 1500 van 5.9 with 3.55's. 255/70/15 tire. The van gets 11mpg. Mine is a high top conversion so I think the limiting factor is the giant sail effect.
It has the Hughes baby cam and EQ heads, magnaflow exhaust and cat. After the rebuild and add ons it still only gets .5 mile per gallon better than the old factory stock all oem van with 155k.
Even switched to electric fan, still no difference. I am about to rebuild the rear end and thinking of switching to 3.92. I have worked with so many of these I am 100% confident it will improve my MPG.
[Re: mgoblue9798]
#2509084
06/15/18 08:20 PM
06/15/18 08:20 PM
cudaman1969
fredericksburg,va
Even switched to electric fan, still no difference. I am about to rebuild the rear end and thinking of switching to 3.92. 2001 3500 5.9 4.10 gears 245/75R 16 tires, I get around 13-14 mpg now. 186,000 miles, new chain, fixed the gasket on the bottom of intake.
[Re: HotRodDave]
#2509085
06/15/18 08:22 PM
06/15/18 08:22 PM
cudaman1969
fredericksburg,va
Interesting, my scanner would stay at 60 then going down a hill would creep to 61 but rpm would go down to 1888. All over the place. I'm thinking the converter is not locking up to well (all new parts, electrical and trans). Will the lockup fluctuate 100 rpm? I have a set of 3.54 for the Dana that I would like to try. Talked to the Dodge service man, he said no problem reflashing pcm for the ratio change. Dont waste money taking it to the dodge dealer for a "flash" after a ratio change, the vehicle speed is measured after the gears and will not affect anything computer related changing gears. What about the speed sensor on the trans (where the old speedo cable went)?
[Re: cudaman1969]
#2509108
06/15/18 09:42 PM
06/15/18 09:42 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
Just checked my van rpm to speed, 4.10 2930-50 @ 60 mph for 15 miles on a hand held diagnostic. 5.9 Magnum 2001. Couple of questions, is this a good rpm for that engines "sweet" spot? Also It's got a lock up converter but the rpm, set at 60 mph on cruise, fluctuates from 1888 to 1955 up and down slight grades but the hand held never goes off 60, is this normal for a new lockup? Take out of overdrive it goes to 2770 rpm @ 60 Thanks It has more rpm in overdrive? "Take out of overdrive" ok, i'm still not understanding. " 4.10 2930-50@60 mph." then you say " take out of overdrive" it goes to 2770@60" if you take it out of overdrive, the rpm should increase. or am i reading this wrong?
#2509215
06/16/18 03:22 AM
06/16/18 03:22 AM
cudaman1969
fredericksburg,va
Just checked my van rpm to speed, 4.10 2930-50 @ 60 mph for 15 miles on a hand held diagnostic. 5.9 Magnum 2001. Couple of questions, is this a good rpm for that engines "sweet" spot? Also It's got a lock up converter but the rpm, set at 60 mph on cruise, fluctuates from 1888 to 1955 up and down slight grades but the hand held never goes off 60, is this normal for a new lockup? Take out of overdrive it goes to 2770 rpm @ 60 Thanks It has more rpm in overdrive? "Take out of overdrive" ok, i'm still not understanding. " 4.10 2930-50@60 mph." then you say " take out of overdrive" it goes to 2770@60" if you take it out of overdrive, the rpm should increase. or am i reading this wrong? Sorry I didn't preview the post very well, rpm should of read 1930 in overdrive.
