Rochester 2bbl how to find the year/model #2502986
06/01/18 01:06 AM
06/01/18 01:06 AM
RapidRobert Offline OP
I need to kit it & the O'reillys guy looked on the computer & in his big book & could not find it. It is an OE Mopar Rochester 2bbl with these #'s 7038417 1389(3)488 4Z02 The (3) might be an 8. Thank you for your time. EDIT it just hit me that he would have ran the # on there & I will give him the other # tomorrow.
Re: Rochester 2bbl how to find the year/model [Re: RapidRobert] #2502998
06/01/18 01:51 AM
06/01/18 01:51 AM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Stamped in numbers are the only ones that will help identify the carb. Raised up numbers, those that are actually casting numbers, won't help on a Rochester.
Re: Rochester 2bbl how to find the year/model [Re: John Brown] #2503007
06/01/18 02:27 AM
06/01/18 02:27 AM
these #'s are stamped. I will recheck if the one # in question is a (3) or an (8)
Re: Rochester 2bbl how to find the year/model [Re: RapidRobert] #2503091
06/01/18 11:03 AM
06/01/18 11:03 AM
md
mopars4ever Offline
mopars4ever  Offline
md
maybe close? http://www.carburetor-parts.com/Rochester-2GV-Carburetor-Kit-1971-Dodge-Plymouth_p_800.html
try this place
https://www.youtube.com/watch?v=gZXHdAVGh78&feature=youtu.be
According to the video earlier years had tags under the screw which may be missing.
Re: Rochester 2bbl how to find the year/model [Re: mopars4ever] #2503152
06/01/18 01:15 PM
06/01/18 01:15 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Since at least 1969, Rochester two barrels had the numbers stamped into a flat side of the float bowl. Earlier they had aluminum tags. I looked at my library edition Rochester Carb book and it is a 1971 edition so no help there. I recall in the 80's 360's having Q-jets, so maybe they also sourced 2 barrels from GM, but that 7038417 number would normally indicate a 70's carb.
Re: Rochester 2bbl how to find the year/model [Re: John Brown] #2503203
06/01/18 03:11 PM
06/01/18 03:11 PM
Chicago
PurpleBeeper Offline
Chicago
No kidding? I only remember 500cfm Holley 2-barrels & themoquad 4-barrels, but I'm no small block expert.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Rochester 2bbl how to find the year/model [Re: PurpleBeeper] #2503226
06/01/18 04:01 PM
06/01/18 04:01 PM
dogdays Offline
dogdays  Offline
It's all here in this link:
http://www.carburetion.com/quadnumber.htm
703 is from the '60s with A.I.R.
8 is 1968
5 means California emissions 2-barrel
1 means Chevrolet
9 odd number means it came in front of a manual transmission.
So it could have come off a 1968 Chevelle with a 307 that was sold in California, 3 on the tree.
Mopars were Carter and Stromberg and Holley if they had to, and much later, Rochester. I cannot remember any Rochester carbs on Mopars until the '70s or 80s.
R.
Re: Rochester 2bbl how to find the year/model [Re: RapidRobert] #2503234
06/01/18 04:14 PM
06/01/18 04:14 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I found that link also but since he said it was a mopar carb I didn`t post it.
Re: Rochester 2bbl how to find the year/model [Re: mopars4ever] #2503264
06/01/18 05:22 PM
06/01/18 05:22 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
In my 1971 Rochester bible there is a non GM section. Listed there are various Checkers, White Trucks, 1971 Cobra Jet 429, Studebakers and 1971 Plymouth.
Carb # 7041180 is listed as 71 Plymouth Valiant, Barracuda and Fury with a 318 2 barrel.
All I know is what the book shows, but an internet search also shows Q-jets on 85 and 86 360's.
But that still doesn't answer Roberts original question. Wish I had more.....
Re: Rochester 2bbl how to find the year/model [Re: RapidRobert] #2503288
06/01/18 06:36 PM
06/01/18 06:36 PM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
IIRC FWIW in 1971 Ma Mopar used Rochester's due to a supplier shortage. I want to say there is a TSB Technical Service Bulletin on this. I'm at work so I can't research it at the moment.
Common sense is a flower that does not grow in everybody's garden
Re: Rochester 2bbl how to find the year/model [Re: RapidRobert] #2503295
06/01/18 06:55 PM
06/01/18 06:55 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Rochester 2GV 2 barrel carburetor kit. More complete, better fitting.
Dodge
1971 318" 5.2L
Dodge Truck
1971 318" 5.2L
Plymouth
1971 318" 5.2L
Carburetor Numbers
7041180
7047100
Re: Rochester 2bbl how to find the year/model [Re: mopars4ever] #2503419
06/02/18 12:49 AM
06/02/18 12:49 AM
Good comprehensive info guys! I went back to O'reillys & he picked a kit that he said matched, the chebby one & it was the wrong kit but he said I could bring it back if that was the case likely since I have been in there several times on this issue plus they want me to switch my acct to them & get away from another parts house that I ain't happy with sooo I am going to take the old air horn to base gasket in & see if it matches the one in the pic he showed me today on the other chebby kit on the screen which is what I should have done first. I did confirm the carb #'s & it has a throttle lever with the horizontle Mopar arm which to my untrained eye sure looks OE Mopar. EDIT the stamped # is 7038417 and 13898488 stamped underneath it then stamped 4Z02
Re: Rochester 2bbl how to find the year/model [Re: RapidRobert] #2503433
06/02/18 01:26 AM
06/02/18 01:26 AM
South Bend
John Brown Offline
John Brown  Offline
South Bend
The 13898488 number googles to a Rochester boat (marine) carburetor. Lots of pictures too.
Re: Rochester 2bbl how to find the year/model [Re: RapidRobert] #2503544
06/02/18 11:58 AM
06/02/18 11:58 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Re: Rochester 2bbl how to find the year/model [Re: mopars4ever] #2503886
06/03/18 01:18 PM
06/03/18 01:18 PM
I made a mistake on the numbers: the 13898488 was in a mini clocking circle on the flat surface under the top air horn. 7038417 is stamped on the main body side with 4Z02 stamped right under it. it has a 1&11/16 bore. here is a pic of the critical gaskets that I would need to match in a kit. the throttle bracket sure looks OE Mopar.
Re: Rochester 2bbl how to find the year/model [Re: RapidRobert] #2503907
06/03/18 01:59 PM
06/03/18 01:59 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
https://carburetion.walkerproducts.com/rochester/rochester-carburetor-kit-2bbl-2g/
Page 11 and 13
Looks like the parts numbers might be G1408 and G520
Don't be the exception.
Re: Rochester 2bbl how to find the year/model [Re: Supercuda] #2503912
06/03/18 02:06 PM
06/03/18 02:06 PM
thank you, I will check it out.
Re: Rochester 2bbl how to find the year/model [Re: RapidRobert] #2504072
06/03/18 09:32 PM
06/03/18 09:32 PM
By accident I stumbled across the alum tag for it: Mercruzer MCM 200/898 then underneath that is 1389-8488 so I thought well that takes care of the kit I need BUT it had NO jets & neither Rochester or Holley jets will screw in. [ Moparts Family Site - Keep it Friendly ]. Any thoughts?
Re: Rochester 2bbl how to find the year/model [Re: RapidRobert] #2504157
06/04/18 12:45 AM
06/04/18 12:45 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Time to seek out another carb.
Re: Rochester 2bbl how to find the year/model [Re: RapidRobert] #2504304
06/04/18 12:03 PM
06/04/18 12:03 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Anytime you find a carb with black finish,it is usually a marine application.
