Timing issue or ?????? Update ..... found problem
#2502444
05/30/18 10:59 PM
05/30/18 10:59 PM
Posts: 1,613 Deerfield, Ohio
70dusterjohn
Deerfield, Ohio
Just had a set of -1s porter along with the intake, now I’m only running 30degs of timing but the car wants to stall, before it was back firing through the intake and now it’s popping through the exhaust.. not much but I can hear it. Any ideas .. my Brian is fried from working on it no stop for 3 days and have had now but problems.. thanks guys
Re: Timing issue or ??????
[Re: 70dusterjohn]
#2502458
05/30/18 11:17 PM
05/30/18 11:17 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
Nothing to add on what these guys have said but Im interested to hear the problem.
1963 Plymouth Max Wedge 1971 Barracuda
[Re: 70dusterjohn]
#2502463
05/30/18 11:24 PM
05/30/18 11:24 PM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
What ignition are you using? Any retard programs in use? Ign boxes don't last forever,,,don't ask how I know,,,,,,,
[Re: 70dusterjohn]
#2502468
05/30/18 11:29 PM
05/30/18 11:29 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Check your plugs. Check your lash. You have raw fuel in the exhaust. Plugs should show you where it’s coming from.
[Re: 70dusterjohn]
#2502563
05/31/18 07:29 AM
05/31/18 07:29 AM
Posts: 11,728 Portage,michigan
B3422W5
Portage,michigan
Sounds to me like sticking needle and seat in the carb
[Re: 70dusterjohn]
#2503446
06/02/18 02:02 AM
06/02/18 02:02 AM
Posts: 43,303 Bend,OR USA
Cab_Burge
There are only a few things that can make your motor do what it is doing, blown head gaskets is one, bad distributor cap is another, bad spark plug wires, vacuum leak is another and so on. I would start with the basics first, compression test, infra red temp gun on the headers after driving it, look very closely inside the distributor cap and so on, one thing at a time ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) Please let us know what you find out ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: 70dusterjohn]
#2503518
06/02/18 11:24 AM
06/02/18 11:24 AM
Posts: 4,243 Charlotte, North Carolina
sgcuda
How did you phase the distributor? I like to drill a 3/8" hole in line with #1 in an old distributor cap and put a timing light on it to check rotor/plug wire alignment. Do you have a 4/7 swap cam and forgot about it when you reran the plug wires? Did you verify TDC timing marks before you started all of this?
[image][/image]
[Re: 70dusterjohn]
#2503572
06/02/18 01:35 PM
06/02/18 01:35 PM
Posts: 1,260 New Mexico
Adobedude
New Mexico
Check to make sure the little carbon button is inside your distributor cap...It's easy to miss. DAMHIK.
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
