Re: Radiator support black-out [Re: charge70] #2503267
06/01/18 05:32 PM
06/01/18 05:32 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I have 4 1970 4-doors here from 3 different plants.
They all have blackout, including the EF8 one which was an allowable exclusion.
Re: Radiator support black-out [Re: Alaskan_TA] #2503268
06/01/18 05:34 PM
06/01/18 05:34 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
What is EF8?
Re: Radiator support black-out [Re: 71birdJ68] #2503284
06/01/18 06:26 PM
06/01/18 06:26 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
Originally Posted By 71birdJ68
What is EF8?
Dark green
Re: Radiator support black-out [Re: charge70] #2503338
06/01/18 09:11 PM
06/01/18 09:11 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
E = 1969, 1st model year used
F = Green
8 = relative darkness/deepness of color
(Example: B3, B5 & B7 blues get darker as the numerical digit increases)
Model year 1965 is A.
Re: Radiator support black-out [Re: 71birdJ68] #2503443
06/02/18 01:58 AM
06/02/18 01:58 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
What is EF8?
It's the paint code for Dark green that was used in 69 and 70. It is one of the darker colors that were exempted from the blackout.
If your car was yellow it should have the blackout
Re: Radiator support black-out [Re: Morty426] #2503482
06/02/18 09:02 AM
06/02/18 09:02 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Maybe it should, but it doesn't. Strange combo to, yellow with dark green top, and interior.
Re: Radiator support black-out [Re: charge70] #2503522
06/02/18 11:27 AM
06/02/18 11:27 AM
A collage of whims
A collage of whims
Oddly enough, my F8 '69 Road Runner did get the blackout. St Louis car, later production as it had the Spring Special stuff.
Re: Radiator support black-out [Re: topside] #2503597
06/02/18 02:45 PM
06/02/18 02:45 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Rocker panel pinch seams got the black out treatment on light colored cars too, correct? Seems like bending down and spraying those over and over would wear you out in a hurry. I can see those being done from down low. Maybe the line had a guy up top and another guy town below spraying at the same time as the cars past by?
Re: Radiator support black-out [Re: charge70] #2542667
08/28/18 07:13 PM
08/28/18 07:13 PM
cbusters Offline
cbusters  Offline
I everybody assuming that the car is on the ground and not either hanging from a rack or on an elevated stand?
Re: Radiator support black-out [Re: cbusters] #2542729
08/28/18 08:47 PM
08/28/18 08:47 PM
Jacksonville Fl
70BigBlockSE Offline
Jacksonville Fl
70 Challenger FK5
Re: Radiator support black-out [Re: 70BigBlockSE] #2542732
08/28/18 08:50 PM
08/28/18 08:50 PM
Jacksonville Fl
Jacksonville Fl
this shot make sit look like it came from directly in front
Re: Radiator support black-out [Re: 70BigBlockSE] #2542744
08/28/18 09:13 PM
08/28/18 09:13 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Could have been painted in the air at first to get the bottom of the rockers and the rad support. Then when it was on the ground someone could have sprayed the rad support straight on to finish the task???
Re: Radiator support black-out [Re: charge70] #2543810
08/31/18 12:31 PM
08/31/18 12:31 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
The Dart Rarefish posted is intriguing; I've owned 3 Darts ('69-'73) & 4 Barracudas from '67-'70, (1 of each year) and none had the upper panel blacked out like that.
Here's my 68 Dart convert. I've got a closeup picture on my home computer. These are the only one I have access to right now that show the blackout on the upper rad support. Just to the left of the horn on the inner fender you can see a lot of black over spray.
Re: Radiator support black-out [Re: burdar] #2543859
08/31/18 01:44 PM
08/31/18 01:44 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
That is what I am used to seeing on my Darts too. No blackout on the bottom of the lower radiator core support. Have seen some with paint on top of the hood latch plate too. I am more of the opinion that it was shot straight on. twocents
JB Rhinehart, Realist
A-Body's RULE!
Re: Radiator support black-out [Re: charge70] #2543870
08/31/18 02:14 PM
08/31/18 02:14 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I'm pretty sure there used to be some at the bottom...and in the middle. It's just worn away from road debris. The lower rad hangs down below the bumper and the center is what you can see through the grill.
