Re: Timing issue or ?????? [Re: 70dusterjohn] #2503796
06/03/18 07:04 AM
06/03/18 07:04 AM
Deerfield, Ohio
70dusterjohn Offline OP
Deerfield, Ohio
Same way I have an old cap I deillrdd a hole in and use a time light to do the phasing
Re: Timing issue or ?????? [Re: 70dusterjohn] #2503964
06/03/18 05:26 PM
06/03/18 05:26 PM
Deerfield, Ohio
Deerfield, Ohio
Well update you guys the crank trigher was bad. I hooked it straight to my msd dizzy and all was fixed ... this was shifting at 5 grand
https://youtu.be/Et_ojQAym7o
This https://youtu.be/w-dkZZ1NCV0
was 4000 rpm..
Re: Timing issue or ?????? [Re: 70dusterjohn] #2503967
06/03/18 05:32 PM
06/03/18 05:32 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Glad you found it! Sounds good!
