Re: Sneak peek pecker extension
[Re: WHITEDART]
#2501601
05/29/18 08:49 AM
05/29/18 08:49 AM
Posts: 4,243 Charlotte, North Carolina
sgcuda
You would think that if the beams can be positioned properly to stage with the tires. The ET beams would be positioned the same way. If I'm wrong, then I've learned something today. Glad I'm putting a spoiler on the front of my Cuda.
[image][/image]
[Re: dodger mope]
#2501636
05/29/18 10:57 AM
05/29/18 10:57 AM
Posts: 3,528 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
on a tour though the Boeing factory we where told one 747 they put 600 gallon of paint on the airplane,thats around 4000 lbs.when its being painted the wheels are on scales! If you will notice many of American Airlines planes are mostly polished not painted. The reason is weight.
[Re: sgcuda]
#2501640
05/29/18 11:07 AM
05/29/18 11:07 AM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
SGcuda the top end beams are higher up.
Have you ever lost to a dragster and think you had him? That wing on the front can mess with you
"Just a Bracket car dressed up like a streetcar"
[Re: sgcuda]
#2501793
05/29/18 03:52 PM
05/29/18 03:52 PM
Posts: 8,165 Left Coast
BobR
Left Coast
So, basically, you are shortening the distance to trip the beams. Might make for a quicker et slip, but in reality, it isn't any faster. I'm building N/A because I need to prove to myself how good I am. I don't need any sort of drag race version of Viagra to help me. Almost laughable for anyone who races heads up.
[Re: Biginchmopar]
#2501817
05/29/18 04:30 PM
05/29/18 04:30 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
I believe the finish line beams are roughly 6 in high you could see how this car would definitely have an advantage over the Dodge Dart
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: WHITEDART]
#2501825
05/29/18 04:43 PM
05/29/18 04:43 PM
WHITEDART
bean town ....Ca
I believe that most tracks staging are 1.5 inches high.. and the finish line can be roughly 6 in high
[Re: WHITEDART]
#2501827
05/29/18 04:45 PM
05/29/18 04:45 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I have been kicking around the idea of putting a stripe taker on my black Duster because I race against so many Dragsters in box class. That would change up the way they line you up at the starting line by about 18 inches. Not really a fan of the ones that stick out past the bumper.
[Re: MR_P_BODY]
#2501890
05/29/18 06:03 PM
05/29/18 06:03 PM
Posts: 43,323 Bend,OR USA
Cab_Burge
Starting line is 3" high.. every thing else is 6" high I remember friends of mine that worked for NHRA division seven saying 3.0 inches off the ground to, I think, the center of the bulb and receiver unit on the staging beams, 6.0 inches on the other end bulbs and recievers ![confused confused](/ubbthreads/images/graemlins/custom/confused.gif) As far as heads up stripe takers NHRA limits the 36.0 inch rule max from the center of the spindle to the front due to the funny cars guys moving the front air dams out further than those cars body styles came with back a long time ago ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif)
[Re: Cab_Burge]
#2501953
05/29/18 09:06 PM
05/29/18 09:06 PM
WHITEDART
bean town ....Ca
Starting line is 3" high.. every thing else is 6" high I remember friends of mine that worked for NHRA division seven saying 3.0 inches off the ground to, I think, the center of the bulb and receiver unit on the staging beams, 6.0 inches on the other end bulbs and recievers ![confused confused](/ubbthreads/images/graemlins/custom/confused.gif) As far as heads up stripe takers NHRA limits the 36.0 inch rule max from the center of the spindle to the front due to the funny cars guys moving the front air dams out further than those cars body styles came with back a long time ago I was wondering if someone can verify the height of the staging beams I keep finding 1.5 to 1 5/8. And some people have mentioned three in on here. some places are saying minimum car height of 3 in... thanks in advance
[Re: WHITEDART]
#2501970
05/29/18 09:49 PM
05/29/18 09:49 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Starting line is 3" high.. every thing else is 6" high I remember friends of mine that worked for NHRA division seven saying 3.0 inches off the ground to, I think, the center of the bulb and receiver unit on the staging beams, 6.0 inches on the other end bulbs and recievers ![confused confused](/ubbthreads/images/graemlins/custom/confused.gif) As far as heads up stripe takers NHRA limits the 36.0 inch rule max from the center of the spindle to the front due to the funny cars guys moving the front air dams out further than those cars body styles came with back a long time ago I was wondering if someone can verify the height of the staging beams I keep finding 1.5 to 1 5/8. And some people have mentioned three in on here. some places are saying minimum car height of 3 in... thanks in advance You have to have 3" of clearance to 12" behind the center line of the spindle.. lesser than 3" you will not pass NHRA inspection(other tracks ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) ) anything past the starting line is 6" EDIT I had to raise my car 1/4" due to the NHRA rule when I built it
[Re: WHITEDART]
#2502081
05/30/18 02:10 AM
05/30/18 02:10 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
The little secret they don't want to mention is that it also increases MPH readings 3-5 mph, so they can brag about how much more Horsepower they have.
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: WHITEDART]
#2502090
05/30/18 02:37 AM
05/30/18 02:37 AM
Posts: 8,361 fredericksburg,va
cudaman1969
fredericksburg,va
This ain't new, back in the early 70s, none other than the "famous" Royce Mller (MIR) had a 69 Camaro with the front spoiler across the front,very low. He would dump the car at he stripe, fooling the other guy into thinking they where ahead. A lot of smart guys around that area at that time. Fuzzy Norton had one of the first delay boxes then also, very hard to beat those guys, no backing into a win.
[Re: MoparBilly]
#2502145
05/30/18 10:36 AM
05/30/18 10:36 AM
Posts: 13,408 Marion, South Carolina [><]
an8sec70cuda
The little secret they don't want to mention is that it also increases MPH readings 3-5 mph, so they can brag about how much more Horsepower they have. How does it do that? If the cones/beams down track are all the same height (lower than the stage beam), how does the extension make the MPH faster? I understand the ET being slightly quicker b/c the distance travelled is thrown off w/ the extension.
[Re: MoparBilly]
#2502159
05/30/18 11:06 AM
05/30/18 11:06 AM
Posts: 11,688 W. Kentucky
justinp61
W. Kentucky
The little secret they don't want to mention is that it also increases MPH readings 3-5 mph, so they can brag about how much more Horsepower they have. How do you figure that? If all the down track beams are 6" off the track the speed will be the same.
[Re: justinp61]
#2502212
05/30/18 01:24 PM
05/30/18 01:24 PM
cudaman1969
fredericksburg,va
The little secret they don't want to mention is that it also increases MPH readings 3-5 mph, so they can brag about how much more Horsepower they have. How do you figure that? If all the down track beams are 6" off the track the speed will be the same. Maybe the tire hits the first one and when the front end drops the pecker hits the last one, less time=faster mph, same as et.?? Can't see it happening if down for both.
[Re: an8sec70cuda]
#2502226
05/30/18 01:48 PM
05/30/18 01:48 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
The little secret they don't want to mention is that it also increases MPH readings 3-5 mph, so they can brag about how much more Horsepower they have. How does it do that? If the cones/beams down track are all the same height (lower than the stage beam), how does the extension make the MPH faster? I understand the ET being slightly quicker b/c the distance travelled is thrown off w/ the extension. MILES PER HOUR TIMER Also known as the speed trap, this timer is located 66 feet before the finish line. It records the car’s average speed between it and the finish line. This is the mile per hour figure on your time slip. So, if the car got there sooner, with the extension, would it fool the timer into a faster speed?
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
