Page 2 of 3 1 2 3
Re: Sneak peek pecker extension [Re: WHITEDART] #2501601
05/29/18 08:49 AM
05/29/18 08:49 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
You would think that if the beams can be positioned properly to stage with the tires. The ET beams would be positioned the same way. If I'm wrong, then I've learned something today. Glad I'm putting a spoiler on the front of my Cuda.
[image][/image]
Re: Sneak peek pecker extension [Re: dodger mope] #2501636
05/29/18 10:57 AM
05/29/18 10:57 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Originally Posted By dodger mope
on a tour though the Boeing factory we where told one 747 they put 600 gallon of paint on the airplane,thats around 4000 lbs.when its being
painted the wheels are on scales!
If you will notice many of American Airlines planes are mostly polished not painted. The reason is weight.
Re: Sneak peek pecker extension [Re: sgcuda] #2501640
05/29/18 11:07 AM
05/29/18 11:07 AM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
SGcuda the top end beams are higher up.
Have you ever lost to a dragster and think you had him? That wing on the front can mess with you
"Just a Bracket car dressed up like a streetcar"
Re: Sneak peek pecker extension [Re: Just-a-dart] #2501718
05/29/18 01:17 PM
05/29/18 01:17 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
I have seen a few write up on this. Here is one
www.dragtimenews.com/BracketRacing101-ItsAllInTheTimingPt2.htm
Re: Sneak peek pecker extension [Re: sgcuda] #2501793
05/29/18 03:52 PM
05/29/18 03:52 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Originally Posted By sgcuda
So, basically, you are shortening the distance to trip the beams. Might make for a quicker et slip, but in reality, it isn't any faster. I'm building N/A because I need to prove to myself how good I am. I don't need any sort of drag race version of Viagra to help me.
Almost laughable for anyone who races heads up.
Re: Sneak peek pecker extension [Re: WHITEDART] #2501794
05/29/18 03:59 PM
05/29/18 03:59 PM
Kirkland, Washington
Pacnorthcuda Offline
1318 feet
Re: Sneak peek pecker extension [Re: Pacnorthcuda] #2501806
05/29/18 04:20 PM
05/29/18 04:20 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
I like it, any and every little thing helps. up
beer
Re: Sneak peek pecker extension [Re: Biginchmopar] #2501817
05/29/18 04:30 PM
05/29/18 04:30 PM
bean town ....Ca
W
WHITEDART Offline OP
W
bean town ....Ca
I believe the finish line beams are roughly 6 in high you could see how this car would definitely have an advantage over the Dodge Dart
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Sneak peek pecker extension [Re: WHITEDART] #2501825
05/29/18 04:43 PM
05/29/18 04:43 PM
bean town ....Ca
W
W
bean town ....Ca
I believe that most tracks staging are 1.5 inches high.. and the finish line can be roughly 6 in high
Re: Sneak peek pecker extension [Re: WHITEDART] #2501827
05/29/18 04:45 PM
05/29/18 04:45 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I have been kicking around the idea of putting a stripe taker on my black Duster because I race against so many Dragsters in box class. That would change up the way they line you up at the starting line by about 18 inches. Not really a fan of the ones that stick out past the bumper.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Sneak peek pecker extension [Re: pittsburghracer] #2501853
05/29/18 05:07 PM
05/29/18 05:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Starting line is 3" high.. every thing else is
6" high
wave
Re: Sneak peek pecker extension [Re: MR_P_BODY] #2501890
05/29/18 06:03 PM
05/29/18 06:03 PM
6" high
wave
I remember friends of mine that worked for NHRA division seven saying 3.0 inches off the ground to, I think, the center of the bulb and receiver unit on the staging beams, 6.0 inches on the other end bulbs and recievers confused
As far as heads up stripe takers NHRA limits the 36.0 inch rule max from the center of the spindle to the front due to the funny cars guys moving the front air dams out further than those cars body styles came with back a long time ago work scope
Re: Sneak peek pecker extension [Re: Cab_Burge] #2501953
05/29/18 09:06 PM
05/29/18 09:06 PM
bean town ....Ca
W
W
bean town ....Ca
6" high
wave
I was wondering if someone can verify the height of the staging beams I keep finding 1.5 to 1 5/8. And some people have mentioned three in on here. some places are saying minimum car height of 3 in... thanks in advance
Re: Sneak peek pecker extension [Re: WHITEDART] #2501970
05/29/18 09:49 PM
05/29/18 09:49 PM
MR_P_BODY Offline
MR_P_BODY  Offline
6" high
wave
You have to have 3" of clearance to 12" behind
the center line of the spindle.. lesser than 3"
you will not pass NHRA inspection(other tracks
shruggy) anything past the starting line is
6"
EDIT
I had to raise my car 1/4" due to the NHRA rule
when I built it
wave
Re: Sneak peek pecker extension [Re: WHITEDART] #2502081
05/30/18 02:10 AM
05/30/18 02:10 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
The little secret they don't want to mention is that it also increases MPH readings 3-5 mph, so they can brag about how much more Horsepower they have.
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: Sneak peek pecker extension [Re: WHITEDART] #2502090
05/30/18 02:37 AM
05/30/18 02:37 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
This ain't new, back in the early 70s, none other than the "famous" Royce Mller (MIR) had a 69 Camaro with the front spoiler across the front,very low. He would dump the car at he stripe, fooling the other guy into thinking they where ahead. A lot of smart guys around that area at that time. Fuzzy Norton had one of the first delay boxes then also, very hard to beat those guys, no backing into a win.
Re: Sneak peek pecker extension [Re: MoparBilly] #2502145
05/30/18 10:36 AM
05/30/18 10:36 AM
an8sec70cuda Offline
How does it do that? If the cones/beams down track are all the same height (lower than the stage beam), how does the extension make the MPH faster? I understand the ET being slightly quicker b/c the distance travelled is thrown off w/ the extension.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Sneak peek pecker extension [Re: MoparBilly] #2502159
05/30/18 11:06 AM
05/30/18 11:06 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
How do you figure that? If all the down track beams are 6" off the track the speed will be the same.
Re: Sneak peek pecker extension [Re: justinp61] #2502212
05/30/18 01:24 PM
05/30/18 01:24 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Maybe the tire hits the first one and when the front end drops the pecker hits the last one, less time=faster mph, same as et.??
Can't see it happening if down for both.
Re: Sneak peek pecker extension [Re: an8sec70cuda] #2502226
05/30/18 01:48 PM
05/30/18 01:48 PM
jersey
Spaceman Spiff Offline
jersey
MILES PER HOUR TIMER
Also known as the speed trap, this timer is located 66 feet before the finish line. It records the car’s average speed between it and the finish line. This is the mile per hour figure on your time slip.
So, if the car got there sooner, with the extension, would it fool the timer into a faster speed?
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Page 2 of 3 1 2 3
