Re: Excessive Heat Under Hood [Re: GTXKARL] #2504418
06/04/18 04:23 PM
06/04/18 04:23 PM
Eugene, Oregon
Secret Chimp Offline
Eugene, Oregon
Make some basic sheet metal heat shields for your manifolds/headers.
Every single car and truck you could buy started running stamped sheetmetal heat shields several decades ago. They reflect radiant heat coming off the exhaust away from the rest of the compartment & down toward where air is flowing off the K frame and towards the floors. They work.
Before I made & installed mine, I couldn't even touch the underside of my air cleaner after driving the car. I just reuse the bottom left/right corner valve cover bolts to mount mine.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: Excessive Heat Under Hood [Re: Secret Chimp] #2504436
06/04/18 05:08 PM
06/04/18 05:08 PM
Kirkland, Washington
Pacnorthcuda Offline
Who knew??? I didn't!
Re: Excessive Heat Under Hood [Re: Secret Chimp] #2504718
06/05/18 10:49 AM
06/05/18 10:49 AM
Maryland
mrob Offline
mrob  Offline
Maryland
Sounds like a good idea. Have any pics you could share? Are these shields just flat plates that go over the headers or do they enclose the header tubes?
Re: Excessive Heat Under Hood [Re: GTXKARL] #2504724
06/05/18 11:00 AM
06/05/18 11:00 AM
Minn
SportF Offline
SportF  Offline
Minn
It was mentioned, I believe, but if you are running your timing at 32-34 this can cause the exhaust to get very hot.
