Re: 9 second hemi cuda, anyone know this car?
[Re: johnnycuda]
#2502311
05/30/18 04:34 PM
05/30/18 04:34 PM
Posts: 4,715 Wichita
GY3
Wichita
I talked to him yesterday, I believe he mentioned the 60' were around the 1.36, leaving in second. Randy is a customer, motor is a 528 aluminum Hemi, runner-up at DW last year, averaged like 9.45, even though he lost first gear in the trans the first day and was launching the rest of the week (and this night at the track) in second gear, best pass at DW was a 9.35, car weighs 3600 w/driver, has our CalTracs and springs, moved inboard 3/4". Any ideal on the 60' with the calTracs? Pretty stout! I leave in 2nd when traction is limited or when I'm using true street radials. 1.72 is the best I've pulled off with them and Cal-Tracs.
[Re: gsmopar]
#2502313
05/30/18 04:34 PM
05/30/18 04:34 PM
Posts: 246 Cranberry Twp PA (North of Pit...
rumblefish72
The time slip for the championship 10.00 run is on the first page ... 1.61 60'. 10.009 on a 10.000 index is slicing hairs to long way! That's pretty close to breaking out. And wining the 9.50 class at the same event ... priceless. I bet a lot of people in the pits were talking about that Purple AAR 'Cuda.
I'd be putting some of my winning $$$ into the basket at Church thanking God for the help.
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
[Re: johnnycuda]
#2502371
05/30/18 07:08 PM
05/30/18 07:08 PM
Posts: 4,087 Mo.
racerx
Mo.
I talked to him yesterday, I believe he mentioned the 60' were around the 1.36, leaving in second. Randy is a customer, motor is a 528 aluminum Hemi, runner-up at DW last year, averaged like 9.45, even though he lost first gear in the trans the first day and was launching the rest of the week (and this night at the track) in second gear, best pass at DW was a 9.35, car weighs 3600 w/driver, has our CalTracs and springs, moved inboard 3/4". Any ideal on the 60' with the calTracs? ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: gsmopar]
#2502374
05/30/18 07:09 PM
05/30/18 07:09 PM
Posts: 861 lancaster,california
johnnycuda
He lost first gear at DW last year, not sure if he got it fixed, or is leaving in second because he wants to, either way, car is a bad sumbitch, and Randy is super nice and cool to talk with.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT! 1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air, New daily driver-2003 Ram 2500 Cummins 5.9 '69 Valiant 2-dr, sleeper! New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
[Re: gsmopar]
#2502401
05/30/18 09:03 PM
05/30/18 09:03 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
It gives me hope that my 572 will run good too....
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: johnnycuda]
#2502430
05/30/18 10:08 PM
05/30/18 10:08 PM
Posts: 984 San Diego CA
65 Hemi
San Diego CA
Do you know if he has a 727 and a gear vendor in the car???
Doug
MOPAR or NO CAR!!! 1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas 1964 Dodge Polara 582" Indy alum Block 426-1RA heads, 1933 Plymouth PE all Steel, LT1 4L60E 1959 Plymouth Savoy 33,000 mile survivor Old cars are never done. They are ongoing projects!
[Re: gsmopar]
#2503224
06/01/18 03:57 PM
06/01/18 03:57 PM
johnnycuda
Yes, has a 727 with a Gear Vendor, has a 4.30 rear gear set. He said first gear is fixed, issue was caused by a aluminum drum, some aluminum from it made its way into the valve body.
