Re: 426 Hemi install
[Re: Dave Hall]
#2501105
05/27/18 09:13 PM
05/27/18 09:13 PM
Posts: 18,157 Mass
DAYCLONA
Mass
I have to disagree here. Why wouldn't you install as much as you can on the engine before it goes in? Saves time, get's things done nice and tidy. Will also save the engine compartment from getting banged up. Your proposal might be fine for a smblk or Bblk install, but the HEMI is a very tight fit in ANY application, I usually like to install from the bottom up, but have done HEMI installs from the top, if going in from the top, no exhaust manifolds as suggested, you might even find yourself removing the valve covers depending on the style used and how much you might have to move the engine around to sit it on the mounts, you'll need to lose any booster/master, you might even have to remove the front shocks as the studs might hit the heads/covers going in...
[Re: tweeter1]
#2501119
05/27/18 10:17 PM
05/27/18 10:17 PM
Posts: 1,385 Az
69hemibeep
Az
If you are using stock valve covers the whole thing will fit from the bottom and you can slip a sheet of cardboard in on each side to keep from scratching the inner fenders. It is tight.
1969 Hemi Roadrunner 2nd owner
[Re: ScottSmith_Harms]
#2501183
05/28/18 12:23 AM
05/28/18 12:23 AM
Posts: 15,976 Chilliwack B.C. Canada
RUNCHARGER
Exactly: It's been a few years for me but it seems to me you can do it with the manifolds on. I seem to remember dropping it down sideways a bit and then swinging it around a few inches into place. Honestly I would install the left manifold in the car (with just the right engine mount secured and the left side lifted a bit) and leave the shocks out. Also pad the inner fenders with thick blankets.
Sheldon
[Re: 6T9Hemi]
#2501186
05/28/18 12:32 AM
05/28/18 12:32 AM
Posts: 10,752 North Dakota
6PakBee
North Dakota
Here's how I put mine in. What engine hoist is that? Looks waaay beefier than what I've seen before.
[Re: NANKET]
#2501229
05/28/18 05:18 AM
05/28/18 05:18 AM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
I didn't want to line up and push the 4 speed from the bottom, so I took some time and put it in as one piece. No damage, wrapped all possible areas with moving blankets.
[Re: tweeter1]
#2501634
05/29/18 10:54 AM
05/29/18 10:54 AM
Posts: 4,580 Motor City
6PKRTSE
Motor City
I have always gone in from the top minus exhaust manifolds/Headers with no issues. (Note: if using Headers, set them down in the engine bay first. Depending on brand and tube sizes they will not go in without a fight).
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#2501639
05/29/18 11:04 AM
05/29/18 11:04 AM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
[Re: tweeter1]
#2501686
05/29/18 12:16 PM
05/29/18 12:16 PM
Posts: 2,060 Pendleton NY
terzmo
Pendleton NY
I installed a hemi in My 67 R/T without any trans. From the top...no issue with steering column or battery tray. Even had the hood on with the hinge bolts loose to give a little extra room. I installed TTI headers after..not a big deal
[Re: terzmo]
#2501838
05/29/18 04:53 PM
05/29/18 04:53 PM
6PKRTSE
Motor City
I installed a hemi in My 67 R/T without any trans. From the top...no issue with steering column or battery tray. Even had the hood on with the hinge bolts loose to give a little extra room. I installed TTI headers after..not a big deal Mine definitely wasn't going in without taking the hood off.
