Re: Anyone make E body side glass guide hairy felt?
[Re: Challenger 1]
#250049
07/18/11 10:59 PM
07/18/11 10:59 PM
Posts: 12,521 Western Colorado High Desert
moparmarks
I just had to do set for a 70 vert I'm working on with new AMD glass. I used the thickest black teri cloth I could find. Was able to reuse the foam padding. Seems to work alright. This is in a high dollar resto-mod so I dought it will see alot of window action.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: moparmarks]
#250050
07/18/11 11:42 PM
07/18/11 11:42 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Has anyone tried stopping by a glass shop & seeing what the installers have... I recently did just that for my Falcon project & they had rolls of material with different types of black fur for window channels, guides & for making catwhiskers....
[Re: 1_WILD_RT]
#250052
07/20/11 01:11 PM
07/20/11 01:11 PM
Posts: 12,478 Warren, MI
71TA
Warren, MI
Good info. I'm gonna stop by and ask. Theres a place RIGHT across the street from my day job.
[Re: 71TA]
#250053
07/28/11 06:54 AM
07/28/11 06:54 AM
Posts: 144 capac michigan
MCB Restorations
capac michigan
I've thought about designing a spring loaded replacement for this "cheesy" Chrysler designed part. This way the window would always be under compression regardless of it's position on the track. There's no way to adjust these where they are in compression at all postions of the window up / down, therefore making the glass rattle when you slam the door. Matt @ MCB www.tuffwheelrestoration.com
Stainless Steel and Aluminum trim restoration by MCB Restorations. We offer show quality trim restoration for all brands but specialize in Mopar. See our website for other examples www.mcbrestorations.com or give us a call at (810) 395-7162
[Re: MCB Restorations]
#250055
07/28/11 08:49 PM
07/28/11 08:49 PM
Posts: 242 midwest
intragration
midwest
I believe these parts are more for additional strength for people who close the doors by the extended glass, rather than for holding it from rattling in the door. It seems that when the door is completely assembled and adjusted properly, that the belt weatherstripping holds it fairly tight from the inside and outside at the top, the mechanism doing this from the bottom, and the downstop preventing the glass from ever going below the belt weatherstripping. These felts, in addition to the felted rubber bumper on the outside are always just supporting the middle of the glass. Additionally, these felt brackets can be adjusted fairly tight due to the thickness of the felt, at least when that thickness is still there, before it's worn down.
My gut feeling after having taken every part out of the door, putting every part back in, and adjusting it properly, is that the factory did a pretty good job of engineering the window mechanisms.
