Re: Thoughts on cyl head repair [Re: fast68plymouth] #2500101
05/24/18 07:30 PM
05/24/18 07:30 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Originally Posted By fast68plymouth
Head gaskets...... Not really a good place to scrimp IMO.
I'd stick with the 4.410 Cometics.
What you're experiencing is why I prefer not to try and make a head into something it's not by excessively porting it.
If you need a bigger head....... And something is available.......its often less expensive in the long run to just get them at the start.
thanks Dwayne ,
the source heads were what I could afford at the time and met my needs . They did run 6 plus years .
These Tf heads are costing me $3800 plus any 10% tax , so down here we do have to budget some items
with the bigger motor well I can now afford a better cyl head . I am not a number chaser , just a street driving bracket racer .
Are you of the opinion the fel1009 are just not good enough ? They list as same bore size and thickness
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Thoughts on cyl head repair [Re: tex013] #2500103
05/24/18 07:44 PM
05/24/18 07:44 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Keep your eyes open for a 10% off coupon when you buy something big like that. I will be attending a 3 day 20,000.00 race next weekend and I'm betting some will be floating around so I will keep my eyes open. A member in the gereral section just gave me one and I ordered slicks today. He gave them all out but one of use will pick up another batch soon.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Thoughts on cyl head repair [Re: ozymaxwedge] #2500109
05/24/18 08:00 PM
05/24/18 08:00 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Originally Posted By ozymaxwedge
How many "budget" racers have re used Cometic head gaskets ? I have, with only a week between races we had to try it, cleaned, copper spayed and perfect.
I reused mine 3 times on my 15-1 572. Never had any issue. Sprung for new ones 4th time around.
Doug
Re: Thoughts on cyl head repair [Re: pittsburghracer] #2500120
05/24/18 09:23 PM
05/24/18 09:23 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
hey John
I used my Summit proshop account , seems around 10% off normally .
Summit have been good and they throw some sponsorship down here .
Doug ,
always a bit leery about reusing gaskets .
Hope to see heads end of next week . Should be a step up from the source ones
Tex
New best MPH 130.32
Re: Thoughts on cyl head repair [Re: tex013] #2500134
05/24/18 10:22 PM
05/24/18 10:22 PM
PA.
"Little"John
"Little"John
PA.
Just for an example on my slicks today. Pro Shop savings was 34.00 but a 10% off coupon came to 61 dollars. not a big savings but 27.00 is 27.00 in my World. That's almost half of my 60.00 entry into Saturdays race. What was really nice was they gave me 20.00 worth of Summit Bucks on one of my past orders. Thank you Summit Racing.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Thoughts on cyl head repair [Re: tex013] #2500137
05/24/18 10:35 PM
05/24/18 10:35 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Here is a pic down 1 port
Over half inch long
Tex
New best MPH 130.32
Re: Thoughts on cyl head repair [Re: tex013] #2500139
05/24/18 10:48 PM
05/24/18 10:48 PM
PA.
"Little"John
"Little"John
PA.
That’s an easy fix there just by tubing the head bolt with K&S brass tubing and JB weld. But the water isn’t coming from there
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Thoughts on cyl head repair [Re: tex013] #2500150
05/24/18 11:46 PM
05/24/18 11:46 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Originally Posted By tex013
Doug ,
Tex
After buying a 1009 Fel set, and .051 and .040 Cometic sets that cost over $800 Aussie Im bleeding from the rectum and will be re using these Cometics next time, they are fine second hand.
1963 Plymouth Max Wedge
1971 Barracuda
Re: Thoughts on cyl head repair [Re: ozymaxwedge] #2500154
05/25/18 12:01 AM
05/25/18 12:01 AM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
[quote=tex013]
Doug ,
Tex
After buying a 1009 Fel set, and .051 and .040 Cometic sets that cost over $800 Aussie Im bleeding from the rectum and will be re using these Cometics next time, they are fine second hand. [/quote
aint this the case . 1009 are $160 pair here Cometics are twice this, have a spare set 0.027 cometics but wont work this motor .
Will not reuse this pair as going different heads
Tex
New best MPH 130.32
Re: Thoughts on cyl head repair [Re: tex013] #2500784
05/26/18 08:39 PM
05/26/18 08:39 PM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
tex you can get them impregnated with a coating resin it works on the indy junk that does the same
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: Thoughts on cyl head repair [Re: Ian] #2500834
05/26/18 10:58 PM
05/26/18 10:58 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Ian ,
What is the resin?
When the dust settles may look at reoair and sell these heads . Worth looking at
Tex
New best MPH 130.32
Re: Thoughts on cyl head repair [Re: tex013] #2500901
05/27/18 05:05 AM
05/27/18 05:05 AM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
Ian ,
What is the resin?
Tex
http://www.redavison.com.au/porosity-sealing-systems-r-e-davison-group/
Re: Thoughts on cyl head repair [Re: tex013] #2500913
05/27/18 07:52 AM
05/27/18 07:52 AM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Thanks Ian
Tex
New best MPH 130.32
