Page 2 of 6 1 2 3 4 5 6
Re: picked up a 80688 holley 1050 to try [Re: Clanton] #2499421
05/23/18 12:02 PM
05/23/18 12:02 PM
So. Burlington, Vt.
fast68plymouth Online content
fast68plymouth  Online Content
So. Burlington, Vt.
I looked at the specs...... I think the stock jetting is likely pretty close.
I'd start with t-slot restrictors....... Something like .065 to start, and idle air bleeds about the same.
Maybe knock the primary jets down one or two sizes.
Re: picked up a 80688 holley 1050 to try [Re: Clanton] #2499422
05/23/18 12:04 PM
05/23/18 12:04 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I have 47/51/55/61/70 air bleeds
Re: picked up a 80688 holley 1050 to try [Re: Clanton] #2499429
05/23/18 12:16 PM
05/23/18 12:16 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I put a 47 in and it only helped 1/2 pt to 10.5 air fuel from 10.0
Re: picked up a 80688 holley 1050 to try [Re: Clanton] #2499437
05/23/18 12:30 PM
05/23/18 12:30 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I put a 70 in and got 11/0.The main jet is 84 from factory.What is this telling us?
ps:I put 80 jets in and got 11.4 a/f
Re: picked up a 80688 holley 1050 to try [Re: Clanton] #2499459
05/23/18 01:27 PM
05/23/18 01:27 PM
So. Burlington, Vt.
So. Burlington, Vt.
Early non-HP style 4500 carb where the only tunable part are the main jets.
This is a 3 circuit 1050 #9375.
I added a "high flow" metering block, which is nothing more than a block with a provision for a PV. The stock blocks have none.
Typical fat and blubbery part throttle operation for this style of carb was corrected by installing transfer slot restrictors.
I usually install changeable air bleeds in these old carbs, but on this one I left them alone.
This carb has very nice part throttle manners now.
Maybe not perfect for a lot if street duty, but vastly improved from how it was from Holley.
Re: picked up a 80688 holley 1050 to try [Re: Clanton] #2499465
05/23/18 01:36 PM
05/23/18 01:36 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
That help some.just fyi this is my carb.
Re: picked up a 80688 holley 1050 to try [Re: Clanton] #2499466
05/23/18 01:37 PM
05/23/18 01:37 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I don't have a pin set to check the jet size
Re: picked up a 80688 holley 1050 to try [Re: Clanton] #2499467
05/23/18 01:39 PM
05/23/18 01:39 PM
So. Burlington, Vt.
So. Burlington, Vt.
You could try the wire trick in the t-slot feeds to see how much affect it has.
Re: picked up a 80688 holley 1050 to try [Re: Clanton] #2499469
05/23/18 01:42 PM
05/23/18 01:42 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Not a professional but i would use a 55 t slot jet, 70 iab 28 mab with float set mid way or slighy less and adjust screws to flavor. Usually 1 to 2 turns. Just my 2cents
Re: picked up a 80688 holley 1050 to try [Re: Clanton] #2499472
05/23/18 01:45 PM
05/23/18 01:45 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Thanks for the t slot jet info and so I need to go bigger or smaller with my rich fuel mix?I see I need to reduce the tslot jet.
Re: picked up a 80688 holley 1050 to try [Re: Clanton] #2499474
05/23/18 01:46 PM
05/23/18 01:46 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
is that a set screw in the transfer slot feed or is it just a brass plug?
i put 8-32 set screws in a 4150 body and it looks similar...
But yeah, i would do the wire trick Fast68 just mentioned, quickest easiest way to test that change...
Re: picked up a 80688 holley 1050 to try [Re: Clanton] #2499477
05/23/18 01:47 PM
05/23/18 01:47 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I will put all jets back to factory accept the pv and try the tslot in my next step.
Re: picked up a 80688 holley 1050 to try [Re: krautrock] #2499478
05/23/18 01:48 PM
05/23/18 01:48 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
set screw
Re: picked up a 80688 holley 1050 to try [Re: Clanton] #2499480
05/23/18 01:51 PM
05/23/18 01:51 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I do have some set screws that I will check for the correct thread size and maybe I can drill them,I have a lot of pin drills
ps:Will I need to do both pri,sec side of the carb?
Re: picked up a 80688 holley 1050 to try [Re: Clanton] #2499481
05/23/18 01:52 PM
05/23/18 01:52 PM
So. Burlington, Vt.
So. Burlington, Vt.
Do you have a 1/16" drill bit?
Is the T-slot restrictor bigger or smaller than that?
Re: picked up a 80688 holley 1050 to try [Re: fast68plymouth] #2499482
05/23/18 01:53 PM
05/23/18 01:53 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I will have to check and may take some time.I have to find my pin drill bits
Re: picked up a 80688 holley 1050 to try [Re: mopar dave] #2499483
05/23/18 01:53 PM
05/23/18 01:53 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
IMO you wont get that cleaned up without the t slot restrictors. Mine ran way cleaner with t slots in the mid 50's. Those t slot orifices are way big. I just could not nail the tune down the way i wanted it, so off it went to Dom@Thumpercarbs.
Re: picked up a 80688 holley 1050 to try [Re: Clanton] #2499484
05/23/18 01:53 PM
05/23/18 01:53 PM
So. Burlington, Vt.
So. Burlington, Vt.
Start with just the pri side to make sure it's having the affect you're hoping for.
Re: picked up a 80688 holley 1050 to try [Re: Clanton] #2499485
05/23/18 01:55 PM
05/23/18 01:55 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Yes on the t-slot restrictors so here's my tune.......
.040 IFR'S lowered
.068-.070 idle bleeds
.026-.028 hi bleeds
.055 t-slots and .082-.088 jetting
You need a vacuum gauge to check for the best power valve and one that comes in as you crowd the throttle while cruising at a steady state speed........too high, rich too soon, too low delayed enrichment..........
Re: picked up a 80688 holley 1050 to try [Re: fast68plymouth] #2499486
05/23/18 01:55 PM
05/23/18 01:55 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Cool thanks!!
