Re: 1958 Dodge Regent
[Re: CrAzYMoPaRGuY]
#2503303
06/01/18 07:15 PM
06/01/18 07:15 PM
Posts: 16,480 Canada
CrAzYMoPaRGuY
Canada
I have a J body. Love the way it drives. I have a 2003 Dakota and love the way it drives MORE! lol
I think though not positive the last 1957 Plymouth I looked at.... he WELDED the front structure in. Didn't bolt it in. Strange but true.
Dakota front clip isn't much harder IMO, and the only options that worry me are the stock setup with Volare spindles. I just worry about the 57 front end, steering and steering box. I don't mind buying bushings, ball joints, steering stuff etc but I want a comfortable 90mph cruiser.....
CrAzYMoPaRGuY
[Re: CrAzYMoPaRGuY]
#2503304
06/01/18 07:17 PM
06/01/18 07:17 PM
CrAzYMoPaRGuY
Canada
I've got a couple Dakotas, I might look closely at them. My 1995 I was going to use for my 1960 Dodge truck project but I'm sure I can grab another somewhere......
CrAzYMoPaRGuY
[Re: CrAzYMoPaRGuY]
#2505089
06/06/18 07:41 AM
06/06/18 07:41 AM
Posts: 1,515 AZ
Mike P
AZ
CrAzYMoPaRGuy, I don't suppose you have or could get pictures of the Plymouth with the 5th Ave suspension? If not could you get me contact info for the guy?
In my mind if I can't make the 605 Steering box conversion I'm trying to work out it might be an option to look at for my Plymouth.
I did a 5th Ave conversion on a 52 F1 pickup many years ago and happy with the results.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold 1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold 1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears) under construction
[Re: Mike P]
#2505397
06/06/18 10:37 PM
06/06/18 10:37 PM
CrAzYMoPaRGuY
Canada
I will look. I think his name was Vic, he lived in nearby Abbotsford. The car was on Kijiji for a few weeks. He said he had done several, and that's after he and his buddies did the first and they loved it. No idea why some don't like the FMJ front end. It's weird to me. He used the Fifth Ave steering column and brake booster/master too.
CrAzYMoPaRGuY
[Re: Mike P]
#2505403
06/06/18 10:49 PM
06/06/18 10:49 PM
CrAzYMoPaRGuY
Canada
I believe I found his name and phone number. I pm'd you his info.
CrAzYMoPaRGuY
[Re: Mike P]
#2505406
06/06/18 10:52 PM
06/06/18 10:52 PM
CrAzYMoPaRGuY
Canada
It wasn't for sale at the Portland Swap Meet 10-15 years ago was it???
CrAzYMoPaRGuY
[Re: CrAzYMoPaRGuY]
#2505500
06/07/18 08:30 AM
06/07/18 08:30 AM
Posts: 1,515 AZ
Mike P
AZ
Thanks for the info!
No the 52 I did was sold locally in AZ and is still in the area.
[Re: CrAzYMoPaRGuY]
#2505568
06/07/18 12:59 PM
06/07/18 12:59 PM
CrAzYMoPaRGuY
Canada
My buddy almost bought a 1950s MoPar truck at Portland Swap meet, FMJ clip and I think it was orange in color but not sure......
CrAzYMoPaRGuY
[Re: CrAzYMoPaRGuY]
#2506850
06/10/18 11:56 PM
06/10/18 11:56 PM
Posts: 10,631 Freeport IL USA
poorboy
Freeport IL USA
I did a 54 Dodge pickup with an FMJ clip. We drove it for 40,000 miles before I sold it on ebay so I could buy a 39 Plymouth coupe. Should have kept the truck! Anyway, my 54 went to the Pacific Northwest someplace, would have been about 15 years ago. It was teal green when it left here.
Lets start out saying that there is NO EASY clip to add onto the frame of anything. All require some level of fabrication.
I have nothing against the FMJ clips other then I believe there are much better options these days. The FMJ subframe was a nice complete Mopar suspension unit that was fairly easy to adapt in the late 80s and early 90s. Most of those installs still involved creating a new front frame structure for the FMJ clip to "bolt" onto. Yes, I did several. Then, the Dakota became available in junk yards and it was a modern suspension with better geometry then the FMJ subframe, and didn't require any more effort to install. Yes, I've done several of those as well. The biggest problem I see with either of these clips today is finding one in good enough condition to actually be able to use it. Here in the rust belt, the rust adds complexity to everything. Gene
[Re: Mike P]
#2572892
11/02/18 04:04 AM
11/02/18 04:04 AM
CrAzYMoPaRGuY
Canada
Neat project, (love the color). If interested I do have a spare pair of original V8 57-58 Dodge and Plymouth frame mounts. The round motor mounts the V8 cars used are still available, but the “cans” that go on the motor can be hard to find and are different than between the Poly/Hemi motors and the B/RB engines. SANYO DIGITAL CAMERA by M Patterson, on Flickr If using the original frame/suspension, you will need a 57-58 center sump pan and pickup is you use a Poly/first gen Hemi. If you go B/RB and can’t find an early passenger car pan, a later B/RB pan will work if going the Big Block route, but it may need to be notched to clear the front crossmember. I’ve done front disc brake conversions a couple of different ways on the 57-58s. 70’s A body Disc brakes were a popular swap 15 years ago (before their were kits using the original spindles). The spindles bolt on, but the tie rods and sleeves need to be shortened and the steering stop modified. I have also used late 70s C body brakes but that is even more work and requires modification to the spindles. I’m using an old AAJ disc brake conversion on my 57 Plymouth’s original spindles and am happy with it. I not sure if AAJ is still in business, but I think Scare Bird has a similar kit. “…….If power steering is, or will be in play, do a Dakota clip……” I absolutely agree with poorboy. If I was just starting to build my 57 Plymouth (or the old 440 powered 57 Coronet I used to have) now it would definitely be getting a later modle front frame clip. The original steering boxes, both manual and especially power boxes suck on these cars. The way the box mounts and oil pan/torsion bar clearance issues make adapting something else (rack and pinion/modern steering box) very difficult is not impossible. I’m currently trying to adapt a 605 Saginaw box into my 57 Plymouth and if it is even possible, it’s going to be a lot of work. In addition to the steering box issues, a couple of other shortcomings include: The upper control arms are a 57-58 only item. They use very small control arm bushings that don’t like heavy engines (first gen Hemis or B/RB motor). Usually the bushings only last about 40-50K miles and are not pleasant to replace. They are also currently getting a little harder to find…..cost can run anywhere between $20 to$50 each (and you need 4). The drag link is also a wear item due to having joints on the outer ends. You can still find these rebuilt, but they are not real cheap. I'm coming up to this soon. I was thinking of retaining the entire front end, rebuilding it and adapting Wilwoods to the front. I already have a spare Wilwood kit for the front AND the back..... I found upper bushings, $40 a piece, I know I need four ... just the cost of doing business I guess. My car is 80,000 original babied miles, manual steering box, I have a power steering box from a 34.000 original mile Dodge given to me too. I am leaning towards a big block. 440 maybe. I will try to lighten, aluminum, water pump and housing, headers, maybe aluminum heads. I'll see what I can do. I have a CH28 and a couple Edelbrock 500s and linkage I was going to toss on my motorhome......
CrAzYMoPaRGuY
[Re: CrAzYMoPaRGuY]
#2572928
11/02/18 09:42 AM
11/02/18 09:42 AM
Posts: 1,515 AZ
Mike P
AZ
A word of advice on the on the steering gear. Regardless of the mileage on the gear send it out to be rebuilt before you install it. You sure don't want to have to pull it back out after you get the interior installed (The gear column and all have to be removed thru the floor into the passenger compartment.
As far as a PS pump there are 2 easy options as far as pump and bracket. One is the older TRW pump....as I recall the pressure is listed as being a little higher than the original pump but it will be fine.
The other option is using the newer brackets and a Saginaw pump. The majority of Saginaw pumps are made for the integral steering gear and has considerably higher pressure than the early Mopar gear is designed for. The trick is to spec a pump for a 70s Corvette with the slave cylinder power steering. Those pumps operate at a lower pressure and should work well with the early Mopar gear.
A couple of other things come to mind if you're using the original front suspension. 57-8 Chrysler Windsor torsion bars will fit under the 57-58 Dodge and Plymouths and are a bit more HD that the stock bars. Factory front sway bars are kind of rare on 57-58 Dodge and Plymouths. If you come across one they were standard on the 57-8 Imperials and will fit the Dodges and Plymouths (I suspect sway bars from Chryslers of that era will also fit). You will need to either cut off the frame brackets or fabricate some (I can send you pictures of the ones I built for my 57 Plymouth if you need them).
[Re: Mike P]
#2573064
11/02/18 03:18 PM
11/02/18 03:18 PM
CrAzYMoPaRGuY
Canada
Absolutely awesome stuff Mike! THANKS!!!!! I bought SuperStocks and a 1966/67 B body 8 3/4 rear.... probably will get 3.23 sure grip and 275/60/15s. Wilwood discs with a parking brake. My car was three in the tree. I already bought a pushbutton shifter assembly and I have a 1965 big block 727 coming, aluminum case and slip yoke. I'll have to figure out a good parking pawl solution I know but I want a pushbutton shifter. I'm going to try Wilwoods on the front. I have a brand new B body drum kit, the inner and outer bearings are the same part number if Rock Auto is correct.... so I will mount the hub on the 58 spindle and see what I need for a bracket. I was looking at making my own if I can't get something to work. These cars ain't cheap to build! lol
CrAzYMoPaRGuY
[Re: Old Ray]
#2584538
11/29/18 03:21 AM
11/29/18 03:21 AM
CrAzYMoPaRGuY
Canada
Kevin, not very good for two reasons.
1. The CV front track is too wide for most applications and uses a weird offset wheel.
2. The original poster appears to be very set on using some kind of early torsion bar suspension (I think). I'm just dead set on a MoPar setup! lol I have no interest in brand X stuff if I can help it. I ended up going with the original 58 front end, rebuilding it all and throwing on some Wilwoods all four corners.... left the F/M/J body clip in my buddy's back yard...... lol
CrAzYMoPaRGuY
[Re: CrAzYMoPaRGuY]
#2585433
11/30/18 11:24 PM
11/30/18 11:24 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Wonder how many know what oil canning is and why they call it that, lol.
[Re: CrAzYMoPaRGuY]
#2585563
12/01/18 08:18 AM
12/01/18 08:18 AM
Posts: 1,515 AZ
Mike P
AZ
".........I ended up going with the original 58 front end, rebuilding it all and throwing on some Wilwoods all four corners........" ".........And I bet it will drive fine........." For what it's worth I agree. I like the handling and feel of the original suspension on my 57 Plymouth. My only mods were Disc brake conversion and addition of a 57/8 Imperial sway bar. I've had a 57 Dodge and my current 57 Plymouth with stock suspensions and driven both cross country and both did very well at highway speeds +. My only complaint was the steering....the power steering has no road feel, and with a heavy engine the manual steering can be a hand full at times. Re reading my last sentence and thinking back , I just realized I didn't mind the manual steering in the Plymouth that much when I first built the car. Of course when I first built the car 12 years ago I didn't have carpal tunnel and arthritis in my right hand and wrist either. By the way I have shelved the idea of adapting a later steering gear to my 57 Plymouth....at least for now. Did you settle on the 440 for power? There are a lot of choices but a 440 sure makes these old boats a fun car. I went back and re-read the thread to refresh my memory and must have missed your post on the original style motor mounts. "......... the original style might worry me because my blandest small block is a healthy hydraulic roller 360. I would probably go up from there as far as power goes and not sure I trust the original style mounts........" Building mounts from scratch using a more modern style motor mount might a bit easier than digging up the original style. Like I said I have an original pair of V8 frame mounts, and I think the rubber part of the mounts are still available new. mount by M Patterson, on Flickr You might have a problem finding the "cans" the mount slips into however, and they are different between the Poly/Hemi and 58 B motor. can by M Patterson, on Flickr FWIW from firsthand experience using the stock mounts and occasionally abusing them, they hold up fine. This was the 440 backed with a pushbutton 65 727 in my old 57 Dodge. 440 by M Patterson, on Flickr And this is the 354 backed by a 4 speed in my 57 Plymouth. 57 354 by M Patterson, on Flickr Both sit on the original style mounts.
