Re: kelsey hayes A-body 4-piston calipers are they all the same?
[Re: 6bblgt]
#2496888
05/16/18 05:18 PM
05/16/18 05:18 PM
Posts: 3,116 Sacramento,California
JRepucci
Are the calipers all the same? what about the combination valve?
what's the correct master cylinder casting number for a '71 with manual disc brakes? Casting number 2225641
[Re: hemi71x]
#2497008
05/16/18 11:40 PM
05/16/18 11:40 PM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
Jim Lusk has stated there are couple of differences with the early ones. There are two differences, but only one is the caliper itself (the other is the retainer, one large retainer on early models and two smaller ones on later). The major difference is the dust seal and how it attaches. Early calipers have a steel ring that the seal goes around (the seal can be installed after the piston) while the later has another groove cut into the cylinder. This is where rebuild kits are critical. Some kits have four of each style while some only have the early seal. This is all because that seal is the same as the 65-67 Mustang.
[Re: JRepucci]
#2497024
05/17/18 12:15 AM
05/17/18 12:15 AM
Posts: 3,394 cheshire, ct
davesmopars
cheshire, ct
what's the correct master cylinder casting number for a '71 with manual disc brakes? Casting number 2225641 this is not the correct one for 71
Keeper of the 440 M code Cuda registry mcodecuda@yahoo.com
