Where to get 1/4 with 1 in washer fire wall heater box nuts #2496239
05/15/18 12:17 AM
05/15/18 12:17 AM
Washougal,Wa
Dodge Offline OP
Dodge  Offline OP
Washougal,Wa
Dang, i ordered 5/16 nuts. Seems all my other cars use this size. The one car im working on now is 1/4 with 1in washer. Where can I find those? Thanks Terry
Stand behind your word
Re: Where to get 1/4 with 1 in washer fire wall heater box nuts [Re: Dodge] #2496245
05/15/18 12:20 AM
05/15/18 12:20 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have you tried the local Fastenal?
Re: Where to get 1/4 with 1 in washer fire wall heater box nuts [Re: stumpy] #2496251
05/15/18 12:27 AM
05/15/18 12:27 AM
Washougal,Wa
Dodge Offline OP
Dodge  Offline OP
Washougal,Wa
No, the 5/16 ones i ordered, showed up today. I wasnt paying attention and there the wrong size. Looks like the other cars are 5/16. This ones 1/4. Just my luck
Re: Where to get 1/4 with 1 in washer fire wall heater box nuts [Re: Dodge] #2496281
05/15/18 02:08 AM
05/15/18 02:08 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
As bad as it sucks ordering the wrong parts sucks, at least it wasn't too expensive.
Order the new one from www.mcmastercarr.com Gene
Re: Where to get 1/4 with 1 in washer fire wall heater box nuts [Re: Dodge] #2496283
05/15/18 02:13 AM
05/15/18 02:13 AM
None
71rm23 Offline
71rm23  Offline
None
Re: Where to get 1/4 with 1 in washer fire wall heater box nuts [Re: Dodge] #2496332
05/15/18 10:41 AM
05/15/18 10:41 AM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
Did you try R/T specialties?
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: Where to get 1/4 with 1 in washer fire wall heater box nuts [Re: RoadRunner] #2496333
05/15/18 10:43 AM
05/15/18 10:43 AM
Washougal,Wa
Dodge Offline OP
Dodge  Offline OP
Washougal,Wa
I looked around a little with no luck. I will try them. Thanks
Re: Where to get 1/4 with 1 in washer fire wall heater box nuts [Re: Dodge] #2496340
05/15/18 10:54 AM
05/15/18 10:54 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
R/T Specialties has them but they are black Phosphate which is incorrect finish.
Little Detroit Restorations has them in the correct finish. Call them to order.304-797-0607
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Where to get 1/4 with 1 in washer fire wall heater box nuts [Re: Dodge] #2496341
05/15/18 11:02 AM
05/15/18 11:02 AM
MA
steve70 Offline
steve70  Offline
MA
MegaParts has them
1970 Challenger T/A 4 speed
Re: Where to get 1/4 with 1 in washer fire wall heater box nuts [Re: Dodge] #2496359
05/15/18 11:29 AM
05/15/18 11:29 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Curious,
What application uses a 1/4" nut with 1" washer on the heater box ?
Re: Where to get 1/4 with 1 in washer fire wall heater box nuts [Re: Dodge] #2496419
05/15/18 01:22 PM
05/15/18 01:22 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
They can be seen on the engine compartment side of the firewall, holding the heater box against/to the firewall.
Joe
Re: Where to get 1/4 with 1 in washer fire wall heater box nuts [Re: jlatessa] #2496448
05/15/18 02:10 PM
05/15/18 02:10 PM
Washougal,Wa
Dodge Offline OP
Dodge  Offline OP
Washougal,Wa
Thanks for all the help
Re: Where to get 1/4 with 1 in washer fire wall heater box nuts [Re: MOPARMIKE69] #2496490
05/15/18 03:21 PM
05/15/18 03:21 PM
RoadRunner Offline
RoadRunner  Offline
Ones on their site are the yellow zinc/cad plated. At least in the picture on their site.
2023 Ford Mach 1
Re: Where to get 1/4 with 1 in washer fire wall heater box nuts [Re: Dodge] #2496495
05/15/18 03:28 PM
05/15/18 03:28 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
As above, Megaparts, a MOPAR supporter.
Under "Heating and Cooling", "Heaterbox hardware and fasteners"
Two choices, according to year...
Joe
