Re: V/P clearance question. '78 360, adding wild cam
[Re: RapidRobert]
#2496412
05/15/18 01:02 PM
05/15/18 01:02 PM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I have to chuckle a bit at this talk of "high rpm" use with the stock 360-2 cam(.410/.410, 203/203, 109.5lsa)....... When the factory hp rating has it peaking at 4000rpm.
[Re: fast68plymouth]
#2496417
05/15/18 01:12 PM
05/15/18 01:12 PM
RapidRobert
which is why I want to upgrade a bit. Not sure where the 4:10's will put us for RPM on that 1/3 mile track but we're sure gonna find out real soon. right now we just need to get out there & worry about being competitive later.
[Re: 4406bbl]
#2496877
05/16/18 05:09 PM
05/16/18 05:09 PM
RapidRobert
^^^ Then I was mistaken on the C clips (its been sitting for 2 years since I brought it home) which is how far behind I am/distracted on things. Thanks for the excellent suggestions/advice guys & I think now I am just gonna toss it in as is just to get up & running (truck pan/pickup needed changing & the silent T chain had a ton of play) & work on the other newly machined 360 which on mockup has SERIOUS VP issues!.
