SB 727 locked up
#2491290
05/03/18 03:38 AM
05/03/18 03:38 AM
Posts: 3,518 pacific northwest
Stroker Scamp
pacific northwest
Had the Duster at the track and second pass after the burnout car slowed at the hit and rear end hopped, drive shaft will not turn in any gear. verified its not the rear end, fluid is clear and good, no issues with linkage checked convertor bolts. Thoughts? this is on a 12.80 340 car any help would be great I am going to talk to the guy who just rebuilt it in the AM but just searching for clues Thanks
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
Re: SB 727 locked up
[Re: Stroker Scamp]
#2491408
05/03/18 12:20 PM
05/03/18 12:20 PM
Posts: 11,819 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Output shaft seized in the rear support. First thing popped into my mind. I don't know how bad a roller clutch or gear set would have to come apart to lock the whole thing up.
[Re: CMcAllister]
#2491736
05/03/18 10:51 PM
05/03/18 10:51 PM
Stroker Scamp
pacific northwest
should also note that its got new sprag and billet front drum going to take it out this weekend
[Re: J_BODY]
#2491758
05/03/18 11:34 PM
05/03/18 11:34 PM
Stroker Scamp
pacific northwest
Yup, the pan will come off first. Question. is there anything that can come out of place and make this happen? No trans guy I am
[Re: Stroker Scamp]
#2491864
05/04/18 10:57 AM
05/04/18 10:57 AM
Posts: 34,976 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Sounds to me like you may have been unlucky and lucky at the same time.
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: Stroker Scamp]
#2492019
05/04/18 03:16 PM
05/04/18 03:16 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
If the fluid's clean, it's not a friction element(s) welded itself together. Parking pawl is in the tail housing but never heard of one of them doing this. Anything failed to cause that will be in the back half/geartrain I would guess. If you start the engine and drop it in gear, does it act like it's in gear or does it free-rev?
[Re: CMcAllister]
#2492086
05/04/18 05:01 PM
05/04/18 05:01 PM
Posts: 26,044 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If the fluid's clean, it's not a friction element(s) welded itself together. Every seized output shaft/support I've seen had cherry red clean fluid.
[Re: Stroker Scamp]
#2492335
05/05/18 09:49 AM
05/05/18 09:49 AM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
Not a 727, but I broke part of the converter snout off of a 904 way back. Happened at highway speed and locked up the driveshaft. Good times right there! I can't remember what the rebuiler said but I'm guessing it shot enough large bits through system when the broken piece made its way into the front pump to wedge fragments in throught the system. I do remember the fluid still seemed fine because it had no time to scorch and the bits were big enough to sink in the pan and not show up on the dipstick.
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
[Re: J_BODY]
#2493477
05/08/18 02:27 AM
05/08/18 02:27 AM
Stroker Scamp
pacific northwest
Guess I’d be dropping the pan to see if it hatched a porcupine egg. If you’ve seen a major trans failure and the ensuing mayhem stuck to the magnet, you’ll know what I’m talking about. No "egg" pretty clear fluid, but not as clean as I would suspect some fuzz on the magnet but not much
[Re: CMcAllister]
#2493478
05/08/18 02:28 AM
05/08/18 02:28 AM
Stroker Scamp
pacific northwest
If the fluid's clean, it's not a friction element(s) welded itself together. Parking pawl is in the tail housing but never heard of one of them doing this. Anything failed to cause that will be in the back half/geartrain I would guess. If you start the engine and drop it in gear, does it act like it's in gear or does it free-rev? no change in rpm from gear to gear
[Re: Stroker Scamp]
#2494502
05/10/18 08:21 PM
05/10/18 08:21 PM
Stroker Scamp
pacific northwest
Dropped the pan and fluid does have quite a bit of fine shiny stuff. Took it in and wound up the sprag failed and chewed into the case, clutches in the front drum some were coming apart. So at this point not exactly sure what caused the failure but any ideas on that would help
[Re: Stroker Scamp]
#2494671
05/11/18 09:39 AM
05/11/18 09:39 AM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
Question when you did your burnouts where you starting out in first gear.
JAKES AUTOMOTIVE
[Re: JAKE68]
#2494831
05/11/18 05:51 PM
05/11/18 05:51 PM
Stroker Scamp
pacific northwest
Question when you did your burnouts where you starting out in first gear. Drive with a stock valve body, that may be the problem
[Re: JohnRR]
#2494832
05/11/18 05:52 PM
05/11/18 05:52 PM
Stroker Scamp
pacific northwest
should also note that its got new sprag and billet front drum going to take it out this weekend what kind of new sprag ? A & A super sprag
