Page 2 of 3 1 2 3
Re: electric fans [Re: RustyM] #2497113
05/17/18 10:25 AM
05/17/18 10:25 AM
Indy
FlyFish Offline
FlyFish  Offline
Indy
2006 Chevy HHR fan, fully shrouded, pulls a ton of air, and only 50 bucks.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: electric fans [Re: dart440_72] #2497120
05/17/18 10:40 AM
05/17/18 10:40 AM
IL
Dart451 Offline
Dart451  Offline
IL
Originally Posted By dart440_72
I had an HHR fan on mine, but recently switched it out. I am using a dual fan setup from a Ford Contour. Works really well. I like it a lot better than my HHR fan
Have apart number or dimensions?
Re: electric fans [Re: Dart451] #2497302
05/17/18 06:28 PM
05/17/18 06:28 PM
Medina, OH
dart440_72 Offline
dart440_72  Offline
Medina, OH
72 Dart 500" low deck Indy SR heads. 10.40 @129 best so far
Re: electric fans [Re: RustyM] #2497438
05/18/18 02:36 AM
05/18/18 02:36 AM
S.E. Minnesota
gtsdude Offline
gtsdude  Offline
S.E. Minnesota
Here are the dimension of the HHR fan, you can take the plastic off the back of the motor and gain a little more room also.
Re: electric fans [Re: RustyM] #2497549
05/18/18 02:22 PM
05/18/18 02:22 PM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
anyone know what the hhr fan weighs?
I cant seem to find it.
Re: electric fans [Re: B3422W5] #2497627
05/18/18 06:08 PM
05/18/18 06:08 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Originally Posted By B3422W5
I bought a derale for my car. Made night and day difference over cheap parts store fan that was on the car when I bought it.
Spal and derale both good fans. I found the better fans that have good motors pull 20+ amps. If they aren't pulling that many amps and have good CFM ratings, run. They won't cut the mustard
I agree 100%. The amps they pull indicates the strength of the motor. A weak fan can move lots of air when there is no restriction placed in front of it, but the CFM drops drastically when you put a radiator in front of it. A strong motor won't slow down as easily.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: electric fans [Re: RustyM] #2497671
05/18/18 08:17 PM
05/18/18 08:17 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Pretty light..........
Re: electric fans [Re: RustyM] #2497698
05/18/18 09:27 PM
05/18/18 09:27 PM
napa ca
P
procharged 484 Offline
P
napa ca
I have a 26 inch champion in 70 challenger need a good pusher ??
Re: electric fans [Re: RustyM] #2497711
05/18/18 10:22 PM
05/18/18 10:22 PM
New York
polyspheric Online content
polyspheric  Online Content
New York
Haven't seen a direct A > B comparo of pusher vs. puller, but the puller always wins.
Boffin Emeritus
Re: electric fans [Re: RustyM] #2497792
05/19/18 06:55 AM
05/19/18 06:55 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I use a 16 inch pusher Spal 3 speed fan with 3 of their mounting straps.
Best way to go,I'm tired of making some junk fans to fit!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: electric fans [Re: RustyM] #2500405
05/25/18 06:26 PM
05/25/18 06:26 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
How deep is this contour fan in the center? Where the water pump would contact?
Re: electric fans [Re: RustyM] #2500638
05/26/18 11:52 AM
05/26/18 11:52 AM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
Thanks to everyone and, keep the ideas rolling in.
Im really torn on the HHR fan vs one's that have advertised cfm ratings.
We are using the Meziere pump ( thanks for the advice moparts) that fits in the mopar housing, we have the aluminum one from 440 source.
It gets really HOT here in Texas - (will be 99 here today) , late June, all of July and August are really tough and it seems to get a little worse each year or, maybe getting old just seems that way- grin.
I'm wanting to leave at 165 consistently if I can pull that off, thats where we have made best power with this engine.
I cannot seem to find any real data on the Cfm rating on the HHR.
Re: electric fans [Re: RustyM] #2500645
05/26/18 12:09 PM
05/26/18 12:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you ran E-85 you can leave at that temp all
of the time.. but I dont know if its in your
area.. on my car with E-85 I had more of a
problem keeping it up to temp
wave
Re: electric fans [Re: RustyM] #2500649
05/26/18 12:16 PM
05/26/18 12:16 PM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
Not sure Mr P- Have to look.
This is a pump gas 511.
question: Is E-85 more consistent than general pump gas?
Re: electric fans [Re: RustyM] #2500656
05/26/18 12:36 PM
05/26/18 12:36 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes it is if you check it before you buy it.. when
I would buy it I would test it first and if it was
within my specs I would pump out 2 drums.. it was
very consistent
wave
Re: electric fans [Re: RustyM] #2500686
05/26/18 02:28 PM
05/26/18 02:28 PM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
Interesting- will do some looking/research.
Re: electric fans [Re: RustyM] #2500780
05/26/18 08:34 PM
05/26/18 08:34 PM
New York
New York
I agree, check it.
But: E85 (like all alcohol-based) is safe to run richer than would hurt power in a race gas. The range of 99% max power is significantly wider.
Your high air temp gives you an advantage! People in Alaska can't get methanol to work w/o a gas primer.
Boffin Emeritus
Re: electric fans [Re: RustyM] #2500789
05/26/18 08:49 PM
05/26/18 08:49 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
Hhr can definitely pulls some air. I have one on my v8 wrangler, it keeps it cool and you should see how small that radiator is.
Re: electric fans [Re: JAMESDART] #2500854
05/26/18 11:49 PM
05/26/18 11:49 PM
hemi-itis Offline
hemi-itis  Offline
If you were asking me..........https://www.jegs.com/i/SPAL/063/30102113/10002/-1
Re: electric fans [Re: JAMESDART] #2502034
05/30/18 12:12 AM
05/30/18 12:12 AM
Medina, OH
dart440_72 Offline
dart440_72  Offline
Medina, OH
3.3 inches. It would contact in the between the center of the fans
Page 2 of 3 1 2 3
