Re: Looking for recommendations on a mechanical fuel pump 440 [Re: 71birdJ68] #2496396
05/15/18 12:26 PM
05/15/18 12:26 PM
moparx Online content
moparx  Online Content
Originally Posted By 71birdJ68
I had the same problem, so answer this. The fuel evaporates out of the carb, ok, I get that, but then tell me how the fuel in the fuel filter disappears from the fuel line all the way down to the pump?
fuel evaporates upward. pour some in a small dish and watch closely. the vapors rise. with an open bowl vent, the vapors rise toward the opening, and eventually, the filter is emptied.
beer
Re: Looking for recommendations on a mechanical fuel pump 440 [Re: Dixie] #2496501
05/15/18 03:35 PM
05/15/18 03:35 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I really think there's a conspiracy from the gas company's. Evaporates faster, your tank emptys faster. Back in the day we used Cam 2 purple, cell would be dry for the next race so we would drain and back in the 55 gal drum. Later we tried the higher octain blue, stayed in cell, didn't evaporate. Came in cheaper since we didn't lose any from evap.
Re: Looking for recommendations on a mechanical fuel pump 440 [Re: moparx] #2496533
05/15/18 05:00 PM
05/15/18 05:00 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I don't think a whole filter, and fuel line will do that in an hour or less. I put a new pump on and it quit that.
Re: Looking for recommendations on a mechanical fuel pump 440 [Re: 71birdJ68] #2497117
05/17/18 10:32 AM
05/17/18 10:32 AM
all gone in less than an hour, you have a problem. glad a pump fixed it.
beer
Re: Looking for recommendations on a mechanical fuel pump 440 [Re: Dixie] #2497143
05/17/18 12:12 PM
05/17/18 12:12 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Had that happen on a Jeep. Shut the engine off and you could watch the filter empty out.
Angry white pureblood male
Re: Looking for recommendations on a mechanical fuel pump 440 [Re: ahy] #2497169
05/17/18 12:57 PM
05/17/18 12:57 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
After all these years I still can't get water to drain uphill after the spring melt. I should put a carb in the low spot on my yard because according to so many guys carbs are great at getting liquids to reverse the affects of gravity! laugh2 Kidding aside, at first glance to a lot of people it seems like the fuel is draining back when the problem is in fact evaporation. Ever put a jerry can of fuel in your trunk on a hot day? Come back later on and it's blown up like a balloon from, imagine what happens in your carb where the bowl vents are open to atmosphere.
Originally Posted By ahy
Agree the pump is likely fine... especially if it runs OK after starting. Fuel evaporation is very likely. I have switched my carb vehicles to electric pump for this reason. Key on for a few seconds re-primes the system and starts right up. This also can eliminate vapor lock.
Same here. I can't think of any good reason to mess around with a mechanical pump these days.
