Re: Magnum swap questions installing a 4 speed behind it
[Re: 79machocharger]
#2494509
05/10/18 09:11 PM
05/10/18 09:11 PM
RapidRobert
5.2 or 5.9? I don't have an answer but this might get some feedback going.
#2494510
05/10/18 09:14 PM
05/10/18 09:14 PM
Posts: 5,443 ME
79machocharger
ME
[Re: Andrewh]
#2494605
05/11/18 01:03 AM
05/11/18 01:03 AM
RapidRobert
I copied this when Dog posted awhile back: 5.9 mag (360) external balance is different from a LA 360 external balance amount. 5.9 mag-use OE 5.9 flexplate/neutral converter. 5.9 Mag imbalance is in the flexplate. 360 LA imbalance is in the converter. 5.2 (318) mags are internally balanced as are all LA 318. 5.2/5.9/LA 360 use the same oil pan (sump locations vary of course-need different pickups) but use mag gasket with 5.2 & 5.9 pan & LA gasket with a 360 LA pan (on a mag block I am assuming he meant). this ain't helping you with a stick app & someone had posted something about some 5.9 mags haveing a different balance than other years of 5.9 LA (Dog will (likely) clarify when he comes to).
#2494632
05/11/18 03:10 AM
05/11/18 03:10 AM
Posts: 5,443 ME
79machocharger
ME
I’ll look around and see if I can find a magnum flywheel.
#2494642
05/11/18 04:32 AM
05/11/18 04:32 AM
Posts: 5,443 ME
79machocharger
ME
Actually I’m not sure, I thought 143.
