Re: Magnum swap questions installing a 4 speed behind it [Re: 79machocharger] #2494650
05/11/18 04:09 AM
05/11/18 04:09 AM
ME
79machocharger Offline OP
ME
Yah carb
Re: Magnum swap questions installing a 4 speed behind it [Re: 79machocharger] #2494652
05/11/18 05:31 AM
05/11/18 05:31 AM
ME
ME
10.5 “ is the diameter I want correct?
Re: Magnum swap questions installing a 4 speed behind it [Re: 79machocharger] #2494737
05/11/18 11:59 AM
05/11/18 11:59 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
If you have a 1970 and up car aluminium bellhousing yes. Other years may be the same I dont know.
Re: Magnum swap questions installing a 4 speed behind it [Re: 79machocharger] #2494903
05/11/18 08:14 PM
05/11/18 08:14 PM
MN
58pwrwgn Offline
58pwrwgn  Offline
MN
When I converted to a 360 my machine shop drilled my neutral flywheel to 360 specs. So I could use it.
Re: Magnum swap questions installing a 4 speed behind it [Re: 79machocharger] #2494984
05/12/18 12:50 AM
05/12/18 12:50 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Yes, someone posted 360 magnum drilling specs on here at one point. I think it was John Kunkle, do a search. The figure I have is 12.82 inch oz of imbalance. If you do a google search specs and location of the hole is out there.
