Re: Shopping for a drive shaft
[Re: mopar dave]
#2493761
05/08/18 09:27 PM
05/08/18 09:27 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
You can check The Driveshaft Shop. He built my old shaft in NY for my Cuda. Still works great. I found out that he is over here in NC, now. Will probably be having him build me an aluminum one this time. I have heard more than once, that guys changing over from M/S to aluminum have seen a difference.
[image][/image]
[Re: sgcuda]
#2493808
05/08/18 11:25 PM
05/08/18 11:25 PM
Posts: 11,786 Portage,michigan
B3422W5
Portage,michigan
You can check The Driveshaft Shop. He built my old shaft in NY for my Cuda. Still works great. I found out that he is over here in NC, now. Will probably be having him build me an aluminum one this time. I have heard more than once, that guys changing over from M/S to aluminum have seen a difference. That's funny, I have never had anybody say they saw anything on a slip going to aluminum. Always hear people saw zip. For years. And I have heard of guys hurting aluminum driveshafts. One such guy is the guy who bought my old car. Just like rollerized trannies. Spent all the money on one years ago, saw nothing.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car Best so far, 10.32 1/4 1.41 best 60 foot 6.56 at 104.17
[Re: B3422W5]
#2493825
05/09/18 12:53 AM
05/09/18 12:53 AM
sgcuda
That's funny, I have never had anybody say they saw anything on a slip going to aluminum. Always hear people saw zip. For years. And I have heard of guys hurting aluminum driveshafts. One such guy is the guy who bought my old car. Just like rollerized trannies. Spent all the money on one years ago, saw nothing. Maybe not in a street car. Guys from 2 different 4.70 groups near me both have told me they have picked up going to aluminum. I didn't ask them, they told me outright. If you hurt an aluminum driveshaft, maybe you shouldn't have bought it at Walmart.
[Re: mopar dave]
#2494006
05/09/18 04:12 PM
05/09/18 04:12 PM
Posts: 12,289 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Pay attentions to material/length/diameter/RPM regarding critical speed. There's a chart on Mark Williams website. Anyone building shafts should know that info and not be guessing.
[Re: mopar dave]
#2494044
05/09/18 05:34 PM
05/09/18 05:34 PM
B3422W5
Portage,michigan
Yes. I understand and agree. Most places are saying cm is way over kill. Dr.Diff suggested the strange 3" cm shaft with the spicer slip yoke for my combo. That seems like plenty shaft for $330. Whats your opinions on the spicer slip yoke strength? I just bought a 1350 forged yoke from Jegs for my 904 swap. Think they get them from inland empire driveline. Spicer should be fine if it isn't cast I have a 727 DTS driveshaft in my car now I am going to sell. Not sure what slip yoke it has. Local outfit is building the new one for my 904.most local racers over here use them. Martin spring and driveline. Have another engine in the works that will make more steam
[Re: mopar dave]
#2494045
05/09/18 05:35 PM
05/09/18 05:35 PM
BradH
I'm going to be in the same situation as soon as the engine & trans are back in the car. I got a new Strange S-60 from Dr. Diff, but he told me to measure things first before I order a new driveshaft, rather than replacing it w/ an OEM-length shaft for an E-body Dana 60 (if that's even possible). 3" vs 3.5"? Not sure how much clearance my bolt-on driveshaft loop has w/ a larger-than-OEM 3.5"... Mild steel vs chro-moly vs ??? 3800#-ish w/ driver, 650+ HP & 600-ish torque, 727 foot-braked, targeting low 10s in the 1/4.
[Re: mopar dave]
#2494139
05/09/18 10:31 PM
05/09/18 10:31 PM
Posts: 10,607 Rittman Ohio
fourgearsavoy
Rittman Ohio
Yes. I understand and agree. Most places are saying cm is way over kill. Dr.Diff suggested the strange 3" cm shaft with the spicer slip yoke for my combo. That seems like plenty shaft for $330. Whats your opinions on the spicer slip yoke strength? That is the exact shaft I just got for my Savoy and it is perfect in every way. Welds look good,slip yoke is strong,joints are solid,and it is perfectly balanced. I used to have a vibration now it's completely gone with the new Strange drive shaft. That Spicer slip yoke is plenty beefy enough for most anything Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: mopar dave]
#2494184
05/10/18 12:04 AM
05/10/18 12:04 AM
Posts: 8,793 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
Talked to dr diff about a driveshaft. Suggested the strange 3" cm with 1350 joints and a spicer yoke for $365. I got one from the Doc for my Bee. Was a nice piece. I'm about to order another.
1969 Dart GTS 340 1969 Coronet R/T X9 N-96 1999 Dodge Dakota R/T RC 2015 Dodge Dart GT 2019 Ram 2500 Big Horn
