Page 2 of 3 1 2 3
Re: . Help diagnose strange noise in drivetrain [Re: 340727dart] #249305
03/10/09 07:34 PM
03/10/09 07:34 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Looks like the nose off a Mini-starter...
Hmm. Now that you mention it, that piece on the left looks like part of a starter.
And the piece on the right I'm waiting for someone from Keisler to ID...
Re: . Help diagnose strange noise in drivetrain [Re: JonC] #249306
03/10/09 07:56 PM
03/10/09 07:56 PM
Witness Protection Program
Kudakidd Offline
Kudakidd  Offline
Muffler bearing.
Re: . Help diagnose strange noise in drivetrain [Re: 1_WILD_RT] #249307
03/10/09 08:11 PM
03/10/09 08:11 PM
South San Francisco, Californi...
MidPenMopar Offline OP
Looking for fun? Keep looking
Yep it's the front of the mini starter that broke off.
It's got probably less than 50 start ups and it already busted.
Is nothing made well anymore??
Thanks guys for the advice as you pointed me in the right direction of where to look.
Stu
Re: . Help diagnose strange noise in drivetrain [Re: MidPenMopar] #249308
03/10/09 09:28 PM
03/10/09 09:28 PM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
Hey Stu i think you have a bolt or a nut loose somewhere...perhaps on the starter
Re: . Help diagnose strange noise in drivetrain [Re: ThermoQuad] #249309
03/10/09 09:30 PM
03/10/09 09:30 PM
More likely in my head.
Re: . Help diagnose strange noise in drivetrain [Re: MidPenMopar] #249310
03/10/09 10:03 PM
03/10/09 10:03 PM
Ontario, Canada
78D150CLUB Offline
My avatar is a self portrait!!
78D150CLUB  Offline
Ontario, Canada
I was thinking the nut behind the wheel might be a bit loose, too.
My son just had the same thing happen on his car, but the whole nose of the starter broke off, right back to the mounting. Jammed in the ring gear and he thought the motor had seized up.
I want to die like my Grampa, peacefully, in his sleep. Not screaming in terror like his passengers.
Re: . Help diagnose strange noise in drivetrain [Re: 78D150CLUB] #249311
03/10/09 10:50 PM
03/10/09 10:50 PM
Oh goody so now it's a class action thing!!!!!!!!!! Where are the mini starter tar and feather smiles!!
Re: . Help diagnose strange noise in drivetrain [Re: Kudakidd] #249312
03/11/09 10:19 AM
03/11/09 10:19 AM
Tennessee
Keisler Sales Offline
Tennessee
Muffler bearing.
That is a great picture.
Stu glad to hear you found out your issue.
Keisler Engineering www.keislerauto.com
#1 Choice of Overdrive Transmissions with Over 14,000 Sold
Re: . Help diagnose strange noise in drivetrain [Re: Keisler Sales] #249313
03/11/09 10:32 AM
03/11/09 10:32 AM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
whats the round piece? What part of the mini starter is that?
and lets see a picture of the broken starter!
Any ideas why it broke? maybe it had been dropped before it was installed??? If its some sort of alignment issue with the ring gear, the next one could break just as fast.
btw, how does the ring gear look?
Re: . Help diagnose strange noise in drivetrain [Re: aarcuda] #249314
03/11/09 10:38 AM
03/11/09 10:38 AM
The piece that broke off is the front end of the mini starter and from what i can see via the inspection area there is no damage to the ring gear luckly. The shop that installed the Keisler transmission is going to replace the mini starter in a few days as they sold it to me. I have no idea why it would break other then a bad casting on the part of the manufacture of the starter. Hopefully yhe next one will not do this again. I drive the roadrunner like a little old lady so i know the breakage was not from any abuse on my part.
Re: . Help diagnose strange noise in drivetrain [Re: MidPenMopar] #249315
03/11/09 11:59 AM
03/11/09 11:59 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Ok i took off the Torque Converer inspection plate and found these parts rattling around in there. What are they??
stu do those 2 pieces fit together ?
I'm going out on a limb and say the Kiesler trans does not have a pilot for the snout of the starter to fit it , so I would be curious to know WHY that broke off
Re: . Help diagnose strange noise in drivetrain [Re: 78D150CLUB] #249316
03/11/09 01:32 PM
03/11/09 01:32 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
did you sons car have a keisler tranny? johnahah may be on to something
Re: . Help diagnose strange noise in drivetrain [Re: JohnRR] #249317
03/11/09 05:33 PM
03/11/09 05:33 PM
I'm going out on a limb and say the Kieselr trans does not have a pilot for the snout of the starter to fit it , so I would be curious to know WHY that broke off
Yes John, the two pieces do fit together to make the nose cone of the starter. I have no idea why it broke but the shop who did the tranny install put the ministarter in at the same time. They are sending a tech over to my place right now to see it.
Re: . Help diagnose strange noise in drivetrain [Re: MidPenMopar] #249318
03/11/09 05:52 PM
03/11/09 05:52 PM
Sacramento, Ca
Darius Offline
Darius  Offline
Sacramento, Ca
Glad you found the problem Stu.
I was going to suggest removing all the empty cans from the trunk and see if that would have made a difference.
Driving modern convenience in classic beauty
Re: . Help diagnose strange noise in drivetrain [Re: Darius] #249319
03/11/09 06:32 PM
03/11/09 06:32 PM
Here's a photo of my original Mopar starter and one of an EXTRA mini-starter i have. This is not the broken one as it's still attached to the engine.
You can see the mini would take up even less room than the standard starter so i do not think it breaking off has anything to do with the Keisler bellhousing.
Re: . Help diagnose strange noise in drivetrain [Re: MidPenMopar] #249320
03/11/09 06:37 PM
03/11/09 06:37 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
Does the Keisler bellhousing have a bunch of empty space in the area of the starter's nose, or is there a relief meant to accept the nose of the starter? From here, it looks like the nose of the mini starter is a bit bigger.
Down to just a blue car now.
Re: . Help diagnose strange noise in drivetrain [Re: 68HemiB] #249321
03/11/09 07:01 PM
03/11/09 07:01 PM
I do know how much room is in the bellhouseing as of now but when they take the broken starter off i sure hope if that is the problem then they can modify it somehow?
The mini starter actually takes up less space than the factory unit. Just hard to see in the photo.
Re: . Help diagnose strange noise in drivetrain [Re: aarcuda] #249322
03/11/09 08:11 PM
03/11/09 08:11 PM
Ontario, Canada
78D150CLUB Offline
78D150CLUB  Offline
Ontario, Canada
No. it,s a stock Brand X. The starter is very similar to the minis, though.
It may be as John says, that the starter is not fitting correctly in the bell housing. If it's being forced out of alignment slightly when it's mounted it could put too much stress on the nose of the starter.
If it has too much opening, the torque of the starter may cause the pilot end of the snout to flex away from the ring gear and stress the housing in the opposite direction.
Either way could result in a fracture over time.
Re: . Help diagnose strange noise in drivetrain [Re: 78D150CLUB] #249323
03/11/09 08:20 PM
03/11/09 08:20 PM
The tech who did the original install stopped by on his way home just now. I told him what you all said about the alignment and he will make sure that is taken into consideration before the re-install of the new mini starter. I take the car back in tomorrow.
Re: . Help diagnose strange noise in drivetrain [Re: MidPenMopar] #249324
03/11/09 08:43 PM
03/11/09 08:43 PM
Redwood City Ca.
B1arno Offline
B1arno  Offline
Redwood City Ca.
One more vote for torque converter bolts.
Arno
Page 2 of 3 1 2 3
