Re: A clutch that will hook with 550-600 crank HP...
[Re: LAR_414]
#249190
03/11/09 08:17 AM
03/11/09 08:17 AM
Posts: 507 Illinois
Hurst390
Illinois
the best money spent in the long run IMO is a mcleod soft-lock or advance single disc..They are race clutches but have light pedal pressure and with the base turned up will work just fine on the street...I would go with the advance unit it is l;ighter and will make your car faster. thats my experience..
80 AMX Barry Allen 420 AMC Iron Heads Jerico 4-speed Advanced clutch 2950# street legal
5.97 115.73 Coles county dragway 10/28/07
9.42 142.96 best in 08(6.00 115.8 1/8)
5.97 116.2 in 09
http://www.youtube.com/watch?v=AXSr201-tmA
[Re: LAR_414]
#249193
03/13/09 01:29 PM
03/13/09 01:29 PM
Posts: 10,645 Houston, Tx
AlexP
Houston, Tx
Read up a little on the LS1 board....some guys have had problems with the Spec clutches.
I'm telling you,...go with a RST and you'll be happy. About $700 or so for on. Not cheap, but a great clutch that will handle the power and be 100% streetable fun!
Oh man, I just typed in LS1 Spec clutch problems on Google....
McLeod it is !
[Re: AlexP]
#249194
03/13/09 03:56 PM
03/13/09 03:56 PM
Posts: 2,064 MD
RTSE4ME
MD
I am looking for a clutch also with a similar HP rating as yours. Going to call these guys and see what they say..... http://www.rochesterclutch.com/racing.shtml
[Re: AlexP]
#249195
03/13/09 07:42 PM
03/13/09 07:42 PM
Posts: 8,038 Tulsa OK
Bad340fish
Tulsa OK
A friend of mine ran a centerforce dual friction on his 93 Cobra with a fuel injected 347. It put down 575 at the tires with the nitrous on 400 on motor only. Went 10.31@128. He didn't have any slippage problems but he did fling the material off of two discs(7000RPM shift point). I also ran the same clutch in my mustang. It wasn't near as fast but the clutch worked great. Smooth engagement and always held.
68 Barracuda Formula S 340
