Re: Brake lights wont shut off... [Re: Scott Carl] #2509424
06/16/18 07:51 PM
06/16/18 07:51 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You should plug in the front sockets and ground them to frame or body so you can tell what's going on. With them not there it may be messing with the ground and causing feedback somehow. I have seen bad grounds on the front lights do very strange things.
Re: Brake lights wont shut off... [Re: Scott Carl] #2510808
06/20/18 02:00 PM
06/20/18 02:00 PM
Omaha, Nebraska
Scott Carl Offline OP
Omaha, Nebraska
Seems to be a flasher issue. with them disconnected, rake lights gone. The taillights appear to be working normal too. Update to come upon installation of new flasher(s)
Re: Brake lights wont shut off... [Re: Scott Carl] #2510811
06/20/18 02:08 PM
06/20/18 02:08 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Since the flashers have no power till it is applied, hazard button or turn signal, I am skeptical. Sounds like you got the hazard flasher out but hte question is, where and why is it getting power?
Don't be the exception.
Re: Brake lights wont shut off... [Re: Scott Carl] #2511053
06/20/18 09:24 PM
06/20/18 09:24 PM
Omaha, Nebraska
Omaha, Nebraska
Well it seems I was mistaken about lights being still on. I was mistaking taillights for brakes after I took the flashers out, rolleyes In my frustration, I was jumping to conclusions and had inadvertently left the taillights on.
Anyway, I have tail and brake lights. And since the turn signals were working, I can only conclude the 4 way flasher was the culprit.
Update upon installing new 4 way flasher
