Re: Best way to avoid water leaks on the ends of HEMI heads?
[Re: domingo]
#2491090
05/02/18 08:38 PM
05/02/18 08:38 PM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
Hylomar is good stuff. Are you using steel shim or copper head gaskets? with a good composition gasket, it shouldn't leak.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: domingo]
#2491119
05/02/18 09:50 PM
05/02/18 09:50 PM
Superfreak
Superfreak
Do you use Hylomar in conjunction with the head gaskets?
[Re: 71birdJ68]
#2491138
05/02/18 10:24 PM
05/02/18 10:24 PM
Posts: 9,670 Lima, Peru
domingo
EL Master
EL Master
Lima, Peru
Be sure not to over torque the corner intake bolts. In the service manual. Yep....but still leaked. I didnt use any sealers though with the 1104 Felpro gasket.
[Re: domingo]
#2491359
05/03/18 10:48 AM
05/03/18 10:48 AM
Posts: 4,866 North of Detroit
HemiDart68
North of Detroit
Verify the heads are decked flat. I had the famous water leaks on heads of that vintage. Found out they were a few thousandths out of square. Machinist did a clean up cut on them and no more leaks. I would be willing to bet that may be an issue on the other no heads of that vintage as well.
In God we trust, all others pay cash.
www.lightnens.com (Home of the world's fastest Paint Job)
[Re: domingo]
#2491360
05/03/18 10:49 AM
05/03/18 10:49 AM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
Never heard of an issue leaking coolant at the corners of the head. I have heard of them leaking oil through the gasket at the lower corners where the drainback passages are. I put a little bit of silicone on both sides of the head gaskets at the drainback holes...no leaks.
[Re: domingo]
#2491369
05/03/18 11:18 AM
05/03/18 11:18 AM
Posts: 2,678 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I would use copper coat. I know some people say they will seal dry but once when I did that I had a leak and another time I had seepage. Now I copper coat and it stays clean.
2011 Drag Pak Challenger
