Re: 1969 Roadrunner Door Panel Questions (A12) (pics inside)
[Re: demon]
#2490503
05/01/18 03:52 PM
05/01/18 03:52 PM
Posts: 712 California
BigDaddy440
California
The "original" doors panels in your picture are not original. Those are early reproductions. Unpadded, crude an missing holes, no Chrysler date stamp. From my experience the PUI panels and upholstery just don't look right either. Interesting, thank you. This would make sense because they were off the car, and the front door panels were not punctured which was part of my confusion. I appreciate your insight.
1969 A12 Roadrunner 1970 Plymouth Cuda 1968 Dodge Dart
[Re: MuscleMopars]
#2490507
05/01/18 03:55 PM
05/01/18 03:55 PM
BigDaddy440
California
FYI, My RM21M9A is an early car with M2T original interior side panels. I'm doing some work on the car and have the front panel off and the rear one is still in. My car has no rear arm rests. And the base for the fronts are not chrome. Here they are... Thank you for the pictures. Although I do like that the PUI panels match my Legendary seat covers, I'm going to send the PUI panels back and get the more accurate Legendary panels that are similar in appearance to the original with the reed insert pattern. I also need to get the standard arm rest bases as well.
