Re: 55* seat thoughts
[Re: B1MAXX]
#2489614
04/29/18 06:31 PM
04/29/18 06:31 PM
Posts: 4,457 Washington
madscientist
Washington
I've used a 55* seat many times. I now would only use it in a blown application or something with a ton of nitrous.
For the N/A stuff I use the 50 almost all the time.
Also, the flatter the port angle the less effective the 55* seat is. As you stand up it the port the 55* gets better.
Now that I've typed all that I would probably still use a 55* seat on a N/A application if the port angle was high enough to get the SSR back in shape.
[Re: B1MAXX]
#2489923
04/30/18 12:23 PM
04/30/18 12:23 PM
Posts: 4,209 New York
polyspheric
New York
Significant effect on the effective flow window during OL (since lift is low), should do better with 1-2 degrees less LSA.
Boffin Emeritus
[Re: rickseeman]
#2489996
04/30/18 02:36 PM
04/30/18 02:36 PM
madscientist
Washington
I'm no expert. I don't think there is any useful benefit until you get over .800" lift. Not true.
[Re: B1MAXX]
#2489998
04/30/18 02:38 PM
04/30/18 02:38 PM
madscientist
Washington
I'll have to see if I put a 55* on a spare valve if it will even leave a margin. 50* looks to have a lot of options. Guess I'll have to experiment. I was just wondering. I know there is a lot of variables bowl shape and such. Also somewhat concerned about durability. A freshen every few years ain't so bad. I also forgot to mention the under head shape of the valve. It's critical. A nail head and steep seats don't like each other. The steeper seats are also tougher on valve faces so you want a good margin.
