Re: Edelbrock 1406 flooding the motor...ideas?
[Re: Posest]
#248969
03/12/09 11:07 PM
03/12/09 11:07 PM
Posts: 649 Davis, California, USA
MrBelvedere2
well i tried putting a fuel pressure regulator on it, i tried 4 psi, and 5 psi and it still wants to flood. I have checked the float adjustment and needle and seats and everything seems to be in order. I guess it's time to send it back to summit and try my luck with another one? anyone recommend any other easy to work with carburetors? I need a 600 cfm 4 barrel electric choke, it's going on a stock 361 big block...thank you for any help.
1965 Plymouth Belvedere II hardtop
[Re: aarcuda]
#248971
03/12/09 11:56 PM
03/12/09 11:56 PM
RapidRobert
Could one of the needle/seat assy's be just barely nicked or a mfg defect enough to be flooding it. With 4 psi you should be good. Unless there's alot of minute debris in the gas I'd go back to the trouble spot which is the inlet valve(needle/seat) & maybe you can buy them seperately without having to go to the trouble of sending the carb back in.
