Page 4 of 4 1 2 3 4
Re: Mallory Unilite timing issue [Re: sgcuda] #2490300
05/01/18 08:37 AM
05/01/18 08:37 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I now have barry Grant blocks from a 750 that i converted and yes IFR were lowered. The new BLP blocks are drilled top and bottom for IFR. They are completely adjustable.
Re: Mallory Unilite timing issue [Re: dartman366] #2490351
05/01/18 10:32 AM
05/01/18 10:32 AM
moparx Offline
Buying your homeless and unwanted bolt on battery terminals
moparx  Offline
Originally Posted By dartman366
Originally Posted By sgcuda
I didn't use a universal tap and die set. I bought specific bottoming taps from tool & die companies. They were a very good fit. Maybe you could tap your blocks to the next size up?
try using form taps they work much better than a standard tap and a lot more accurate sizing.
when using form taps, make sure you use the correct size drill, as form taps require a larger size drill than cut [regular] taps of the same size thread pitch.
beer
Page 4 of 4 1 2 3 4
