Wix 51515 options needed
#2488610
04/27/18 10:54 AM
04/27/18 10:54 AM
Posts: 368 michigan
turbo toad
michigan
I have the Wix 51515 oil filter on my BB motor and I'm have some fitment issues running some charge piping around it and could really benefit from a shorter oil filter. I like the KP S15 billet reuseable oil filter and could gain close to 2 inches in space. But funds are a little tight right now else I just pull the trigger on one. Does Wix make a short oil filter that will work on a Big Block? If anyone has a part number for a shorter oil filter even if it's another brand I'd appreciate it.
Check out my build on Facebook Ttoad Hurley its updated regularly
Re: Wix 51515 options needed
[Re: max_maniac]
#2488649
04/27/18 12:10 PM
04/27/18 12:10 PM
Posts: 368 michigan
turbo toad
michigan
5151R it's the WIX race filter
Is the 5151r shorter in size?
[Re: Sammy]
#2488653
04/27/18 12:22 PM
04/27/18 12:22 PM
Posts: 368 michigan
turbo toad
michigan
how about this?
https://www.ebay.com/itm/Engine-Oil-Filter-MOPAR-MO-090/253553982320?epid=110238980&hash=item3b08febb70:g:VcoAAOSwtuBa2n9h&vxp=mtr
or this
https://www.ebay.com/itm/Challenger-Charger-300-SRT-SRT8-Mopar-Performance-Oil-Filter-5-7L-6-1L-6-4L-8-4L/191725968858?epid=84102048&hash=item2ca3c21dda:g:ZqEAAOSw~OVW1Z5E&vxp=mtr These look smaller and may be a option I'll need to check that the thread pitch is the same thou
[Re: turbo toad]
#2488657
04/27/18 12:30 PM
04/27/18 12:30 PM
RapidRobert
51085 3.790" tall. 51068 4.338" tall Not sure on the microns or capacities. I'm assuming these are Wix #'s (my note taking is poor!) the 51515 you have is 5.180" tall
[Re: turbo toad]
#2488659
04/27/18 12:33 PM
04/27/18 12:33 PM
Posts: 368 michigan
turbo toad
michigan
Thanks guys yes the 51515 is alitttle over 5 inches I'll see if the parts store has a 51085. I'm cramped for space and every inch I can gain goes a long away.
[Re: turbo toad]
#2488673
04/27/18 12:52 PM
04/27/18 12:52 PM
Posts: 715 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
one more, the 51521 is .050 shorter then the 51085 and has the same specs.
Joe
Without Data, you’re just another guy with an opinion.
[Re: turbo toad]
#2488679
04/27/18 01:09 PM
04/27/18 01:09 PM
Posts: 368 michigan
turbo toad
michigan
Thanks Mr P
I talked to the parts store and they have 51085 on the shelf but I'll check and see about The 51521 also Joe
[Re: turbo toad]
#2488699
04/27/18 02:35 PM
04/27/18 02:35 PM
Posts: 1,824 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
Thanks Mr P
I talked to the parts store and they have 51085 on the shelf but I'll check and see about The 51521 also Joe make sure that's not the white one with the fine micron for initial startup and break in.
[Re: Sammy]
#2488700
04/27/18 02:45 PM
04/27/18 02:45 PM
Posts: 368 michigan
turbo toad
michigan
Thanks Mr P
I talked to the parts store and they have 51085 on the shelf but I'll check and see about The 51521 also Joe make sure that's not the white one with the fine micron for initial startup and break in. Ok Sammy I have 2 of the 51515 at the house now and will run one of them on break in,as my charge piping won't be hooked up then.
[Re: turbo toad]
#2488724
04/27/18 05:04 PM
04/27/18 05:04 PM
sr4440
Central TEXAS!!!!
the 51515, 51085, 51521 are all 21 microns @ 7-9 gpm. the 57035 is 32 microns at 7-9 GPM. the 51515R is 61 microns at 28 GPM.
[Re: turbo toad]
#2488731
04/27/18 05:26 PM
04/27/18 05:26 PM
Posts: 10,233 Someplace you aren't
SomeCarGuy
I think 85068 is the shorty for use with a low mount power steering. The 515 hits the belts on those applications.
I want my fair share
[Re: turbo toad]
#2488741
04/27/18 05:54 PM
04/27/18 05:54 PM
Sammy
Wind Gap,Pa.
Thanks Mr P
I talked to the parts store and they have 51085 on the shelf but I'll check and see about The 51521 also Joe make sure that's not the white one with the fine micron for initial startup and break in. Ok Sammy I have 2 of the 51515 at the house now and will run one of them on break in,as my charge piping won't be hooked up then. breakin should be the white one only, with very fine micron. not sure of the part # offhand. I just took my breakin filter off, it caught most of the assembly lube moly. after the 51515 should be put on.
[Re: turbo toad]
#2488747
04/27/18 06:07 PM
04/27/18 06:07 PM
Sammy
Wind Gap,Pa.
Is the 5151r shorter in size? NO Turbo, that's full length but filters only 61 microns. Breakin filter 51515 filters like 19 microns but is also full length.
