Page 1 of 3 1 2 3
Wix 51515 options needed #2488610
04/27/18 10:54 AM
04/27/18 10:54 AM
michigan
turbo toad Offline OP
michigan
I have the Wix 51515 oil filter on my BB motor and I'm have some fitment issues running some charge piping around it and could really benefit from a shorter oil filter. I like the KP S15 billet reuseable oil filter and could gain close to 2 inches in space. But funds are a little tight right now else I just pull the trigger on one. Does Wix make a short oil filter that will work on a Big Block? If anyone has a part number for a shorter oil filter even if it's another brand I'd appreciate it.
Check out my build on Facebook Ttoad Hurley its updated regularly
Re: Wix 51515 options needed [Re: turbo toad] #2488613
04/27/18 10:59 AM
04/27/18 10:59 AM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
how about this?
https://www.ebay.com/itm/Engine-Oil-Filter-MOPAR-MO-090/253553982320?epid=110238980&hash=item3b08febb70:g:VcoAAOSwtuBa2n9h&vxp=mtr
or this
https://www.ebay.com/itm/Challenger-Charger-300-SRT-SRT8-Mopar-Performance-Oil-Filter-5-7L-6-1L-6-4L-8-4L/191725968858?epid=84102048&hash=item2ca3c21dda:g:ZqEAAOSw~OVW1Z5E&vxp=mtr
Re: Wix 51515 options needed [Re: Sammy] #2488642
04/27/18 11:55 AM
04/27/18 11:55 AM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
5151R it's the WIX race filter
Re: Wix 51515 options needed [Re: max_maniac] #2488649
04/27/18 12:10 PM
04/27/18 12:10 PM
michigan
michigan
Is the 5151r shorter in size?
Re: Wix 51515 options needed [Re: Sammy] #2488653
04/27/18 12:22 PM
04/27/18 12:22 PM
michigan
michigan
Originally Posted By Sammy
how about this?
or this
These look smaller and may be a option I'll need to check that the thread pitch is the same thou
Re: Wix 51515 options needed [Re: turbo toad] #2488656
04/27/18 12:26 PM
04/27/18 12:26 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
The 51515 filter is 5.19 inches tall. http://www.wixfilters.com/Lookup/PartDetails.aspx?Part=193964
the 51085 filter is 3.83 inches tall.
http://www.wixfilters.com/Lookup/PartDetails.aspx?Part=160797
Same mounting (3/4-16), same diameter
both have a 7-9 gpm flow rate.
FYI the 51515R is 5.17 inches tall.
http://www.wixfilters.com/Lookup/PartDetails.aspx?Part=76220
Joe
Without Data, you’re just another guy with an opinion.
Re: Wix 51515 options needed [Re: turbo toad] #2488657
04/27/18 12:30 PM
04/27/18 12:30 PM
51085 3.790" tall. 51068 4.338" tall Not sure on the microns or capacities. I'm assuming these are Wix #'s (my note taking is poor!) the 51515 you have is 5.180" tall
Re: Wix 51515 options needed [Re: turbo toad] #2488659
04/27/18 12:33 PM
04/27/18 12:33 PM
michigan
michigan
Thanks guys yes the 51515 is alitttle over 5 inches I'll see if the parts store has a 51085.
I'm cramped for space and every inch I can gain goes a long away.
Re: Wix 51515 options needed [Re: RapidRobert] #2488671
04/27/18 12:48 PM
04/27/18 12:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The 57035 is 2.305 in height 3/4-16 .. watch the
flow ratings on some of the short filters
EDIT
If you click on this page you can look up the
specs on any Wix filter
http://www.wixfilters.com/Lookup/Exactmatch.aspx?PartNo=57035
wave
Re: Wix 51515 options needed [Re: turbo toad] #2488673
04/27/18 12:52 PM
04/27/18 12:52 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
one more, the 51521 is .050 shorter then the 51085 and has the same specs.
Joe
Re: Wix 51515 options needed [Re: turbo toad] #2488679
04/27/18 01:09 PM
04/27/18 01:09 PM
michigan
michigan
Thanks Mr P
I talked to the parts store and they have 51085 on the shelf but I'll check and see about The 51521 also Joe
Re: Wix 51515 options needed [Re: turbo toad] #2488699
04/27/18 02:35 PM
04/27/18 02:35 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Originally Posted By turbo toad
Thanks Mr P
make sure that's not the white one with the fine micron for initial startup and break in.
Re: Wix 51515 options needed [Re: Sammy] #2488700
04/27/18 02:45 PM
04/27/18 02:45 PM
michigan
michigan
Thanks Mr P
Ok Sammy I have 2 of the 51515 at the house now and will run one of them on break in,as my charge piping won't be hooked up then.
Re: Wix 51515 options needed [Re: turbo toad] #2488724
04/27/18 05:04 PM
04/27/18 05:04 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
the 51515, 51085, 51521 are all 21 microns @ 7-9 gpm.
the 57035 is 32 microns at 7-9 GPM.
the 51515R is 61 microns at 28 GPM.
Re: Wix 51515 options needed [Re: turbo toad] #2488725
04/27/18 05:05 PM
04/27/18 05:05 PM
Cab_Burge Online work
Cab_Burge  Online Work
How about using a remote mounted oil filter to get it out of your way altogether work I like and use the big remote mounted NASCAR race filters, Wix # 51222R with the built in high pressure bypass or the Wix #57400R with full flow with no internal bypass scope
Re: Wix 51515 options needed [Re: turbo toad] #2488731
04/27/18 05:26 PM
04/27/18 05:26 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I think 85068 is the shorty for use with a low mount power steering. The 515 hits the belts on those applications.
I want my fair share
Re: Wix 51515 options needed [Re: turbo toad] #2488741
04/27/18 05:54 PM
04/27/18 05:54 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Thanks Mr P
breakin should be the white one only, with very fine micron. not sure of the part # offhand. I just took my breakin filter off, it caught most of the assembly lube moly.
after the 51515 should be put on.
Re: Wix 51515 options needed [Re: turbo toad] #2488747
04/27/18 06:07 PM
04/27/18 06:07 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
NO Turbo, that's full length but filters only 61 microns. Breakin filter 51515 filters like 19 microns but is also full length.
Re: Wix 51515 options needed [Re: turbo toad] #2488812
04/27/18 08:33 PM
04/27/18 08:33 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Plenty of small oil filters that fit that space with the same gasket and thread pitch. I believe my 340 runs one from an Escort. Less capacity, but no biggie as you'll never let it get that dirty.
Doug
Re: Wix 51515 options needed [Re: turbo toad] #2488851
04/27/18 10:43 PM
04/27/18 10:43 PM
Newville, PA
RThunder Offline
RThunder  Offline
Newville, PA
In Fram numbers
The PH8A is the long filter. PH43 is the short filter. Cross reference these numbers. A lot of factory big blocks (most) used the short filter to clear belts, etc
Page 1 of 3 1 2 3
